查看: 2314|回复: 2
OK113核心板系统启动偶尔出现VFS: Cannot open root device
A40i\T3\T507\T527通行证i.MX8MP通行证RK3568通行证RK3399通行证T113i通行证
wolongtest 发表于 2024-11-28 14:45:55 | 显示全部楼层 |阅读模式
采用ok113核心板, 启动有一点概率出现启动失败,断电重启又恢复正常了,从串口调试打印来看,提示VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6造成系统启动失败崩溃
请问如何处理避免这个情况? 谢谢
启动出错日志如下:
[73]HELLO! BOOT0 is starting!
[76]BOOT0 commit : 09b36272
[78]set pll start
[80]fix vccio detect value:0xc0
[87]periph0 has been enabled
[90]set pll end
[92][pmu]: bus read error
[94]board init ok
[96]DRAM only have internal ZQ!!
[99]get_pmu_exist() = -1
[102]DRAM BOOT DRIVE INFO: V0.32
[105]DRAM CLK = 792 MHz
[107]DRAM Type = 3 (2DR2,3DR3)
[110]DRAMC ZQ value: 0x7b7bfb
[113]DRAM ODT value: 0x42.
[116]ddr_efuse_type: 0x0
[118]mark_id: 0x34
[121]DRAM SIZE =512 M
[123]PLL_DDR_CTRL_REG:0xf8004100
[126]DRAM_CLK_REG:0xc0000000
[129][TIMING DEBUG] MR2= 0x18
[136]DRAM ** test OK.
[139]rtc standby flag is 0x0, super standby flag is 0x0
[144]dram size =512
[147]card no is 2
[148]sdcard 2 line count 4
[151][mmc]: mmc driver ver 2021-05-21 14:47
[160][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[166][mmc]: ***Try MMC card 2***
[190][mmc]: RMCA OK!
[192][mmc]: mmc 2 bias 0
[196][mmc]: MMC 5.1
[198][mmc]: HSSDR52/SDR25 4 bit
[200][mmc]: 50000000 Hz
[203][mmc]: 7456 MB
[204][mmc]: ***SD/MMC 2 init OK!!!***
[299]Loading boot-pkg Succeed(index=0).
[303]Entry_name        = u-boot
[310]Entry_name        = optee
[314]Entry_name        = dtb
[317]tunning data addr:0x430003e8
[320]Jump to second Boot.
[366]FORLINX: auth pass!
M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
U-Boot 2018.05-svn863 (Sep 23 2024 - 01:55:35 +0000) Allwinner Technology
[00.418]CPU:   Allwinner Family
[00.421]Model: sun8iw20
I2C:   ready
[00.440]DRAM:  512 MiB
[00.444]Relocation Offset is: 1cebe000
[00.472]secure enable bit: 0
E/TC:0   fdt_getprop_u32:343 prop trace_level not found
[00.485]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.492]gic: sec monitor mode
[00.494]flash init start
[00.496]workmode = 0,storage type = 2
[00.500][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
[00.506][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.530][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.537]sunxi flash init ok
[00.539]Loading Environment from SUNXI_FLASH... OK
disp_type:1
[00.558]line:717 init_clocks
[00.561]drv_disp_init
request pwm success, pwm3:pwm3:0x2000c00.
[00.578]drv_disp_init finish
[00.581]boot_gui_init:start
[00.583]set disp.dev2_output_type fail. using defval=0
tv skip open
[00.890]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read in 0 ms
[00.904]bmp_name=bootlogo.bmp size 1036854
1036854 bytes read in 23 ms (43 MiB/s)
[00.944]Item0 (Map) magic is bad
[00.947]the secure storage item0 copy0 magic is bad
[00.951]Item0 (Map) magic is bad
[00.954]the secure storage item0 copy1 magic is bad
[00.959]Item0 (Map) magic is bad
secure storage read widevine fail
[00.965]secure storage read widevine fail with:-1
secure storage read ec_key fail
[00.972]secure storage read ec_key fail with:-1
secure storage read ec_cert1 fail
[00.979]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[00.987]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[00.994]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[01.002]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[01.009]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[01.017]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[01.024]secure storage read rsa_cert3 fail with:-1
[01.029]usb burn from boot
delay time 0
weaktg_phy_config
[01.040]usb prepare ok
[01.143]overtime
[01.146]do_burn_from_boot usb : no usb exist
List file under ULI/factory
** Unrecognized filesystem type **
[01.158]update part info
[01.161]update bootcmd
[01.163]change working_fdt 0x5c87de70 to 0x5c85de70
[01.169][mmc]: no mmc-hs400-1_8v!
[01.171][mmc]: no mmc-hs200-1_8v!
[01.174][mmc]: get max-frequency ok 50000000 Hz
[01.192]update dts
disp_type:1
Hit any key to stop autoboot (Spacebar):  0
[02.549]no vendor_boot partition is found
Android's image name: sun8i_arm
[02.567]Starting kernel ...
[02.570][mmc]: mmc exit start
[02.587][mmc]: mmc 2 exit ok
[    0.000000] Linux version 5.4.61 (qzy@docker_a40it113) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Wed Sep 4 08:45:06 UTC 2024
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] earlycon: uart8250 at MMIO32 0x02500000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 16 MiB at 0x5f000000
[    0.000000] On node 0 totalpages: 131072
[    0.000000]   Normal zone: 1024 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s30976 r8192 d22272 u61440
[    0.000000] pcpu-alloc: s30976 r8192 d22272 u61440 alloc=15*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=16M snum= mac_addr=b6:a4:ac:d4:f6:1c wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-svn863(09/23/2024-01:55:35) disp_reserve=1658880,0x5c902000 androidboot.dramsize=512
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stackff, heap allocff, heap freeff
[    0.000000] Memory: 483304K/524288K available (6144K kernel code, 327K rwdata, 1868K rodata, 1024K init, 288K bss, 24600K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000]         Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x250/0x3d0 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008382] Switching to timer-based delay loop, resolution 41ns
[    0.014833] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.025019] Console: colour dummy device 80x30
[    0.029708] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.040565] pid_max: default: 32768 minimum: 301
[    0.045559] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.053237] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.061976] CPU: Testing write buffer coherency: ok
[    0.067446] /cpus/cpu@0 missing clock-frequency property
[    0.073044] /cpus/cpu@1 missing clock-frequency property
[    0.078625] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.085114] Setting up static identity map for 0x40100000 - 0x40100060
[    0.092106] rcu: Hierarchical SRCU implementation.
[    0.097423] BOOTEVENT:        97.413082: ON
[    0.102016] smp: Bringing up secondary CPUs ...
[    0.107991] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.108145] smp: Brought up 1 node, 2 CPUs
[    0.118416] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.124897] CPU: All CPU(s) started in SVC mode.
[    0.130311] devtmpfs: initialized
[    0.146366] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.154946] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.165291] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.173207] pinctrl core: initialized pinctrl subsystem
[    0.180144] NET: Registered protocol family 16
[    0.186577] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.229644] rtc_ccu: sunxi ccu init OK
[    0.236125] ccu: sunxi ccu init OK
[    0.240207] r_ccu: sunxi ccu init OK
[    0.280200] iommu: Default domain type: Translated
[    0.285947] sunxi iommu: irq = 24
[    0.291518] pwm module init!
[    0.296509] clocksource: Switched to clocksource arch_sys_counter
[    0.312382] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[    0.331558] thermal_sys: Registered thermal governor 'step_wise'
[    0.331564] thermal_sys: Registered thermal governor 'user_space'
[    0.339237] NET: Registered protocol family 2
[    0.351248] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.360054] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.368244] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.375771] TCP: Hash tables configured (established 4096 bind 4096)
[    0.382575] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.389463] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.396993] NET: Registered protocol family 1
[    0.402060] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[    0.410767] spi spi1: spi1 supply spi not found, using dummy regulator
[    0.417843] sunxi_spi_resource_get()2160 - [spi1] SPI MASTER MODE
[    0.424272] sunxi_spi_resource_get()2198 - Failed to get sample mode
[    0.430932] sunxi_spi_resource_get()2203 - Failed to get sample delay
[    0.437662] sunxi_spi_resource_get()2207 - sample_mode:-1431633921 sample_delay:-1431633921
[    0.446481] sunxi_spi_clk_init()2249 - [spi1] mclk 100000000
[    0.453106] sunxi_spi_probe()2663 - [spi1]: driver probe succeed, base e081d000, irq 44
[    0.463475] Initialise system trusted keyrings
[    0.468340] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[    0.486933] fuse: init (API version 7.31)
[    0.520466] NET: Registered protocol family 38
[    0.525136] Key type asymmetric registered
[    0.530338] Asymmetric key parser 'x509' registered
[    0.535537] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.543341] io scheduler mq-deadline registered
[    0.548108] io scheduler kyber registered
[    0.552425] atomic64_test: passed
[    0.557104] [DISP]disp_module_init
[    0.561283] disp 5000000.disp: Adding to iommu group 0
[    0.567337] [DISP] disp_init,line:2386:
[    0.567342] smooth display screen:0 type:2 mode:11
[    0.576763] [DISP] disp_init_hdmi,line:1047:
[    0.576767] dont support hdmi
[    0.584692] [DISP] bsp_disp_sync_with_hw,line:658:
[    0.584697] Can't find device(2) for manager 0
[    0.587138] [DISP]disp_module_init finish
[    0.599829] sunxi_sid_init()563 - insmod ok
[    0.604662] pwm-regulator: supplied by regulator-dummy
[    0.611371] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.619955] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[    0.628479] uart uart0: get regulator failed
[    0.632951] uart uart0: uart0 supply uart not found, using dummy regulator
[    0.640550] uart0: ttyAS0 at MMIO 0x2500000 (irq = 33, base_baud = 1500000) is a SUNXI
[    0.648885] sw_console_setup()1819 - console setup baud 115200 parity n bits 8, flow n
[    0.657240] printk: console [ttyAS0] enabled
[    0.666475] printk: bootconsole [uart8250] disabled
[    0.677896] uart uart1: get regulator failed
[    0.682710] uart uart1: uart1 supply uart not found, using dummy regulator
[    0.690835] uart uart1: uart1 set rs485 mode, gpio202
[    0.696575] uart1: ttyAS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
[    0.706167] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[    0.715241] uart uart2: get regulator failed
[    0.720083] uart uart2: uart2 supply uart not found, using dummy regulator
[    0.728190] uart uart2: uart2 set rs485 mode, gpio203
[    0.733903] uart2: ttyAS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
[    0.743635] uart uart3: get regulator failed
[    0.748482] uart uart3: uart3 supply uart not found, using dummy regulator
[    0.756592] uart uart3: uart3 set rs485 mode, gpio204
[    0.762307] uart3: ttyAS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
[    0.772021] uart uart4: get regulator failed
[    0.776873] uart uart4: uart4 supply uart not found, using dummy regulator
[    0.784955] uart uart4: uart4 set rs485 mode, gpio205
[    0.790710] uart4: ttyAS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
[    0.800396] uart uart5: get regulator failed
[    0.805209] uart uart5: uart5 supply uart not found, using dummy regulator
[    0.813281] uart5: ttyAS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
[    0.823114] deinterlace 5400000.deinterlace: Adding to iommu group 0
[    0.830826] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[    0.839596] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
[    0.846908] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[    0.854728] [ADDR_MGT] addr_mgt_probe: success.
[    0.861564] libphy: Fixed MDIO Bus: probed
[    0.867882] sunxi gmac driver's version: 1.0.0
[    0.873062] gmac-power0: NULL
[    0.876392] gmac-power1: NULL
[    0.879748] gmac-power2: NULL
[    0.884612] i2c /dev entries driver
[    0.889668] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.900552] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[    0.909515] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
[    0.919499] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
[    0.925906] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
[    0.932275] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
[    0.938737] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[    0.945184] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[    0.951745] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[    0.958301] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[    0.964847] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[    0.971441] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    0.981055] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.004811] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.029093] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[    1.036243] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.038534] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[    1.055556] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[    1.056566] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.064263] rpmsg_tty_init: Sunxi rpmsg tty driver will init
[    1.076279] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.081168] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
[    1.102134] NET: Registered protocol family 10
[    1.108307] Segment Routing with IPv6
[    1.112591] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.121017] NET: Registered protocol family 17
[    1.126033] NET: Registered protocol family 15
[    1.131547] Registering SWP/SWPB emulation handler
[    1.137478] Loading compiled-in X.509 certificates
[    1.144366] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.147556] tv_probe()1527 - of_property_read_string tv_power failed!
[    1.156302] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.163722] get_key_map_info()179 - Failed to find "tvou" in dts.
[    1.181923] tve_clk_config()894 - screen[0] clk_parent is NULL
[    1.183081] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.188497] tv probe finished!
[    1.189077] [DISP] disp_device_attached,line:159:
[    1.189082] attached ok, mgr0<-->device0, type=2
[    1.214331] disp_al_manager_apply ouput_type:2
[    1.219039] sunxi-i2c sunxi-i2c0: sunxi-i2c0 supply twi not found, using dummy regulator
[    1.229917] at24 0-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    1.238342] lm75 0-004e: hwmon1: sensor 'lm75b'
[    1.244025] sunxi-i2c sunxi-i2c0: probe success
[    1.249682] sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
[    1.259230] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    1.271718] sunxi-i2c sunxi-i2c1: probe success
[    1.277412] sunxi-i2c sunxi-i2c3: sunxi-i2c3 supply twi not found, using dummy regulator
[    1.289517] rtc-pcf8563 3-0051: registered as rtc0
[    1.295311] rtc-pcf8563 3-0051: setting system clock to 2024-11-28T06:22:57 UTC (1732774977)
[    1.305584] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.315434] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.325254] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.335105] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    1.345115] sunxi-i2c sunxi-i2c3: probe success
[    1.356579] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    1.398500] input: user-key as /devices/platform/user-key/input/input0
[    1.405982] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
[    1.407481] clk: Not disabling unused clocks
[    1.422689] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
[    1.434916] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
[    1.443658] Please append a correct "root=" boot option; here are the available partitions:
[    1.453057] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
[    1.464676] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    1.473943] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #1
[    1.480573] Hardware name: Generic DT based system
[    1.485961] [<c010e2d8>] (unwind_backtrace) from [<c010a89c>] (show_stack+0x10/0x14)
[    1.494645] [<c010a89c>] (show_stack) from [<c0604b90>] (dump_stack+0x7c/0x98)
[    1.502744] [<c0604b90>] (dump_stack) from [<c0119d04>] (panic+0x104/0x3dc)
[    1.510553] [<c0119d04>] (panic) from [<c0a01278>] (mount_block_root+0x258/0x300)
[    1.518945] [<c0a01278>] (mount_block_root) from [<c0a014bc>] (prepare_namespace+0x118/0x178)
[    1.528503] [<c0a014bc>] (prepare_namespace) from [<c0619274>] (kernel_init+0x8/0x118)
[    1.537379] [<c0619274>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.545861] Exception stack(0xde43dfb0 to 0xde43dff8)
[    1.551520] dfa0:                                     00000000 00000000 00000000 00000000
[    1.560685] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.569850] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.577267] CPU1: stopping
[    1.580299] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #1
[    1.586929] Hardware name: Generic DT based system
[    1.592302] [<c010e2d8>] (unwind_backtrace) from [<c010a89c>] (show_stack+0x10/0x14)
[    1.600983] [<c010a89c>] (show_stack) from [<c0604b90>] (dump_stack+0x7c/0x98)
[    1.609080] [<c0604b90>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
[    1.617275] [<c010c690>] (handle_IPI) from [<c0375934>] (gic_handle_irq+0x70/0x78)
[    1.625763] [<c0375934>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[    1.634146] Exception stack(0xde477f80 to 0xde477fc8)
[    1.639807] 7f80: 000005ac debc1574 00000000 c0115240 00000002 de476000 c0b04e68 c0b04ea4
[    1.648974] 7fa0: 4000406a 410fc075 00000000 00000000 c0b788b0 de477fd0 c0107fb8 c0107fbc
[    1.658137] 7fc0: 60000113 ffffffff
[    1.662047] [<c01021cc>] (__irq_svc) from [<c0107fbc>] (arch_cpu_idle+0x2c/0x38)
[    1.670340] [<c0107fbc>] (arch_cpu_idle) from [<c013e938>] (do_idle+0xb8/0x120)
[    1.678534] [<c013e938>] (do_idle) from [<c013ec3c>] (cpu_startup_entry+0x18/0x1c)
[    1.687019] [<c013ec3c>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[    1.694836] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
shuishui 发表于 2024-12-2 08:54:06 | 显示全部楼层
有没有试过重新烧写镜像呢,之前有遇到过镜像损坏出现这个问题
楼主| wolongtest 发表于 2024-12-2 13:50:54 | 显示全部楼层
断电重新开机启动正常,说明镜像应该没有损坏
是否有可能是emmc初始化检测失败造成?
