查看: 1907|回复: 0
[技术分享] 芯驰D9-Pro开发板OK-D9360-C的多路AHD摄像头实现
LS1028A通行证i.MX8MM通行证i.MX8MP通行证i.MX9596通行证i.MX9352\i.MX9131通行证RK3568通行证RK3588通行证RK3576通行证RK3562通行证RK3506通行证RV1126通行证AM62x通行证A40i\T3\T507\T527通行证T536通行证T153通行证2K0300\2K0500通行证JH7110通行证D9360通行证G2L通行证
gxliu08 发表于 2024-12-3 17:50:07 | 显示全部楼层 |阅读模式
OK-D9360-C开发板支持2路MIPI-CSI接口,可以实现8個1080P AHD 摄像头接入。
已经研制可用的器件有NEXTCHIP N4、NEXTCHIP NVP6188等常用AHD转MIPI CSI芯片。
软件上需要修改内核dts文件,增加驱动程序。
&csimipi1 {
        status = "okay";
        lanerate = <1200000000>;
        hsa = <10>;
        hbp = <20>;
        hsd = <0x60>;
        output-type = <0x1e>;
        ports {
                #address-cells = <1>;
                #size-cells = <0>;
                port@0 {
                        #size-cells = <0>;
                        reg = <0>;
                        csimipi1_0_in: endpoint@0 {
                                remote-endpoint = <&cam1_to_mipi_0>;
                                reg = <0>;
                        csimipi1_0_out: endpoint@1 {
                                remote-endpoint = <&csi1_stream0_in>;
                                reg = <0>;
                port@1 {
                        #size-cells = <0>;
                        reg = <1>;
                        csimipi1_1_in: endpoint@0 {
                                remote-endpoint = <&cam1_to_mipi_1>;
                                reg = <1>;
                        csimipi1_1_out: endpoint@1 {
                                remote-endpoint = <&csi1_stream1_in>;
                                reg = <1>;
                port@2 {
                        #size-cells = <0>;
                        reg = <2>;
                        csimipi1_2_in: endpoint@0 {
                                remote-endpoint = <&cam1_to_mipi_2>;
                                reg = <2>;
                        csimipi1_2_out: endpoint@1 {
                                remote-endpoint = <&csi1_stream2_in>;
                                reg = <2>;
                port@3 {
                        #size-cells = <0>;
                        reg = <3>;
                        csimipi1_3_in: endpoint@0 {
                                remote-endpoint = <&cam1_to_mipi_3>;
                                reg = <3>;
                        csimipi1_3_out: endpoint@1 {
                                remote-endpoint = <&csi1_stream3_in>;
                                reg = <3>;
};&#8203;
