查看: 2763|回复: 2
[Linux] 请问OK6231 烧录自己编译的固件后无法启动怎么解决?
RK3568通行证AM62x通行证FCU11xx通行证
lhwdev 发表于 2024-12-20 10:19:53 | 显示全部楼层 |阅读模式
用下载的固件制作SD卡烧录能启动,用下载的代码,把编译后的制作成SD卡烧录后就不能启动,问题日志如下:
U-Boot 2023.04 (Dec 13 2023 - 05:38:52 +0000)
SoC:   AM62X SR1.0 HS-FS
Model: Texas Instruments AM625 SK
DRAM:  1 GiB
Core:  81 devices, 31 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
splashfile is <NULL>,bootpart is 0:2
3072056 bytes read in 31 ms (94.5 MiB/s)
59305 bytes read in 14 ms (4 MiB/s)
Unknown command ' - try 'help'
Saving Environment to MMC... Writing to MMC(0)... OK
Net:   eth0: ethernet@8000000port@1
Hit space key to stop autoboot:  0
## Error: "findfdt" not defined
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
MMC: no card present
** Bad device specification mmc 1 **
Couldn't find partition mmc 1:1
Can't set block device
21522944 bytes read in 131 ms (156.7 MiB/s)
Working FDT set to 88000000
4835 bytes read in 14 ms (336.9 KiB/s)
4402 bytes read in 14 ms (306.6 KiB/s)
failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND
398 bytes read in 14 ms (27.3 KiB/s)
failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC
base fdt does did not have a /__symbols__ node
make sure you've compiled with -@
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
0: Exit to console
1: Reboot
2: Display type
通过网络方式启动是可以的,然后用网络方式更新Image和dtb文件,重启还是不能启动
1. 证明固件是没有问题的,能启动
2. 证明是确实更新了的
楼主| lhwdev 发表于 2024-12-20 15:07:38 | 显示全部楼层
贴一个正常启动的日志
DRAM:  1 GiB
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
60231 bytes read in 15 ms (3.8 MiB/s)
Unknown command '8 - try 'help'
60231 bytes read in 14 ms (4.1 MiB/s)
4977 bytes read in 14 ms (346.7 KiB/s)
4575 bytes read in 14 ms (318.4 KiB/s)
730 bytes read in 14 ms (50.8 KiB/s)
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.33-g36fc74346200-dirty (root@ubuntu) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Dec 20 09:28:17 CST 2024
87岁拄拐上分 发表于 2025-3-12 09:45:22 | 显示全部楼层
烧录过程是没有问题的对吧,看一看虚拟机源码内这个位置下是否有相关设备树文件
OK62xx-linux-sdk6.1/OK62xx-linux-fs/rootfs/boot
