查看: 2056|回复: 3
[Android] 按照教程使用uuu下载Android镜像时报错
A40i\T3\T507\T527通行证i.MX6Q通行证i.MX8MM通行证
科技引领时代 发表于 2025-3-6 10:58:38 | 显示全部楼层 |阅读模式
uuu_imx_android_flash.bat -f imx8mm -e -c 7
This script is validated with uuu 1.2.91 version, please align with this version.
find: 'b.o.o.t.l.o.a.d.e.r._.b.': No such file or directory
find: 'd.t.b.o.': No such file or directory
find: 'r.e.c.o.v.e.r.y.': No such file or directory
find: 'b.o.o.t._.b.': No such file or directory
generate lines to flash partition-table-7GB.img to the partition of gpt
generate lines to flash u-boot-imx8mm.imx to the partition of bootloader0
generate lines to flash boot-imx8mm.img to the partition of boot
generate lines to flash system.img to the partition of system
generate lines to flash vendor.img to the partition of vendor
generate lines to flash vbmeta-imx8mm.img to the partition of vbmeta
uuu script generated, start to invoke uuu with the generated uuu script
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.2.91-0-g3799f4d
Wait for Known USB Device Appear...
Error: fail open file: >boot-imx8mm.img.link
Forlinx-Mayj 发表于 2025-3-6 11:17:12 | 显示全部楼层
“下载”Android镜像? 烧录吧,什么报错,重新烧录试试呢。确认镜像无误吗
楼主| 科技引领时代 发表于 2025-3-6 11:30:29 | 显示全部楼层
完全是按照教程来的,控制台报错如下,环境是windows11
试试在linux上进行烧写  详情 回复 发表于 2025-3-6 14:09
Forlinx-Mayj 发表于 2025-3-6 14:09:50 | 显示全部楼层
Thi ...
试试在linux上进行烧写
