查看: 2351|回复: 2
[Linux] RK3506板卡全编译报错
RK3506通行证
不爱学习的吉力 发表于 2025-7-10 23:58:09 | 显示全部楼层 |阅读模式
forlinx@ubuntu:~/work/OK3506_Linux_Source$ ./build.sh chip
Log colors: message notice warning error fatal
Log saved at /home/forlinx/work/OK3506_Linux_Source/output/sessions/2025-07-10_23-51-35
Pick a chip:
1. ok3506
2. rk3506
Which would you like? [1]: 1
Switching to chip: ok3506
Pick a defconfig:
1. OK3506-S_linux_emmc_defconfig
2. OK3506-S_linux_emmc_tb_defconfig
3. OK3506-S_linux_nand_defconfig
4. OK3506-S_linux_nand_tb_defconfig
5. OK3506-S_linux_sdmmc_defconfig
Switching to defconfig: /home/forlinx/work/OK3506_Linux_Source/device/rockchip/.chip/OK3506-S_linux_emmc_defconfig
make: *** No rule to make target 'OK3506-S_linux_emmc_defconfig'.  Stop.
ERROR: Running /home/forlinx/work/OK3506_Linux_Source/device/rockchip/common/build-hooks/00-config.sh - switch_defconfig failed!
ERROR: exit code 2 from line 22:
    make $(basename "$DEFCONFIG")
ERROR: call stack:
    00-config.sh: switch_defconfig(22)
    00-config.sh: choose_defconfig(62)
    00-config.sh: choose_chip(98)
    00-config.sh: init_hook(173)
    build-helper: try_func(47)
    build-helper: try_hook(96)
    build-helper: source(155)
    00-config.sh: main(190)
Log saved at /home/forlinx/work/OK3506_Linux_Source/output/sessions/2025-07-10_23-57-54
Pick a chip:
1. ok3506
2. rk3506
Pick a defconfig:
Which would you like? [1]: 3
Switching to defconfig: /home/forlinx/work/OK3506_Linux_Source/device/rockchip/.chip/OK3506-S_linux_nand_defconfig
make: *** No rule to make target 'OK3506-S_linux_nand_defconfig'.  Stop.
ERROR: call stack:
RK3506通行证
楼主| 不爱学习的吉力 发表于 2025-7-13 08:53:46 | 显示全部楼层
问题已经解决,需要把软件资料\2-镜像及源码\1-源码\OK3506_Linux_Source.tar.bz2里面两个文件都拷贝到Linux然后才可以编译
uboot有源码么?  详情 回复 发表于 2025-7-28 11:55
RK3506通行证
bigzhu 发表于 2025-7-28 11:55:51 | 显示全部楼层
问题已经解决,需要把软件资料\2-镜像及源码\1-源码\OK3506_Linux_Source.tar.bz2里面两个文件都拷贝到Linu ...
uboot有源码么?
