查看: 1848|回复: 2
[Linux] Forlinx Desktop 22.04 运行flutter出现问题
RK3568通行证
Fors1y 发表于 2025-8-21 09:32:09 | 显示全部楼层 |阅读模式
forlinx@ok3568:/opt/flutter-apps$ ./build/linux/arm64/release/bundle/flutter_application_1
libGL error: glx: failed to create dri3 screen
libGL error: failed to load driver: rockchip
libGL error: glx: failed to create dri2 screen
[FATAL:flutter/shell/gpu/gpu_su**ce_gl_delegate.cc(79)] Check failed: gl_version_string. The GL proc resolver's glGetString(GL_VERSION) failed
已中止 (核心已转储)
在Forlinx Desktop 22.04 运行flutter程序出现问题
forlinx@ok3568:/opt/flutter-apps$ glxinfo -B
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Mesa (0xffffffff)
    Device: llvmpipe (LLVM 15.0.7, 128 bits) (0xffffffff)
    Version: 23.2.1
    Accelerated: no
    Video memory: 3905MB
    Unified memory: yes
    Preferred profile: core (0x1)
    Max core profile version: 3.0
    Max compat profile version: 3.0
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
    VBO free memory - total: 0 MB, largest block: 0 MB
    VBO free aux. memory - total: 2805 MB, largest block: 2805 MB
    Texture free memory - total: 0 MB, largest block: 0 MB
    Texture free aux. memory - total: 2805 MB, largest block: 2805 MB
    Renderbuffer free memory - total: 0 MB, largest block: 0 MB
    Renderbuffer free aux. memory - total: 2805 MB, largest block: 2805 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 4293983622 MB
    Total available memory: 4293987527 MB
    Currently available dedicated video memory: 0 MB
OpenGL vendor string: Mesa
OpenGL renderer string: llvmpipe (LLVM 15.0.7, 128 bits)
OpenGL version string: 3.0 Mesa 23.2.1-1ubuntu3.1~22.04.3
Mesa 23.2.1-1ubuntu3.1~22.04.3 implementation error: Invalid GLSL version in shading_language_version()
Please report at https://gitlab.freedesktop.org/mesa/mesa/-/issues
OpenGL shading language version string: (null)
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 23.2.1-1ubuntu3.1~22.04.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
有opengl 但是没有硬件加速 用的cpu渲染 我现在要怎么做 ,可以让flutter程序在这个3568板子上面成功运行呢?
RK3576通行证
HenryLiang 发表于 2025-12-8 20:30:07 | 显示全部楼层
你都用flutter了   怎么不用Android开发
RK3568通行证RK3588通行证
宽广我心 发表于 2025-12-27 11:49:38 | 显示全部楼层
如果使用SSH登录,关闭并单独使用debug串口登录,在所使用的命令前sudo,即使使用root用户登录的情况下,再测试试试看
