查看: 1178|回复: 0
[Linux] 关于OK3506B编译问题
RK3568通行证RK3506通行证T536通行证T153通行证
kwx-618 发表于 2025-12-11 21:54:00 | 显示全部楼层 |阅读模式
Please check details in /home/forlinx/Public/OK3506_Linux_Source/output/sessions/2025-12-11_21-49-13/br-rockchip_ok3506_nand_2025-12-11_21-47-08.log
ERROR: Running /home/forlinx/Public/OK3506_Linux_Source/device/rockchip/common/scripts/mk-rootfs.sh - build_buildroot failed!
ERROR: exit code 1 from line 16:
    "$RK_SCRIPTS_DIR/mk-buildroot.sh" $RK_BUILDROOT_CFG "$IMAGE_DIR"
ERROR: call stack:
    mk-rootfs.sh: build_buildroot(16)
    mk-rootfs.sh: build_hook(297)
    mk-rootfs.sh: main(326)
ERROR: Running /home/forlinx/Public/OK3506_Linux_Source/device/rockchip/common/build-hooks/99-all.sh - build_all failed!
ERROR: exit code 1 from line 21:
    "$RK_SCRIPTS_DIR/mk-rootfs.sh"
ERROR: call stack:
    99-all.sh: build_all(21)
    99-all.sh: build_hook(136)
    build-helper: try_func(63)
    build-helper: try_hook(96)
    build-helper: source(165)
    99-all.sh: main(147)
ERROR: Running /home/forlinx/Public/OK3506_Linux_Source/device/rockchip/common/build-hooks/99-all.sh - try_func build_hook all failed!
ERROR: exit code 1 from line 67:
    build_hook
ERROR: call stack:
    build-helper: try_func(67)
有大神知道原因吗?
