查看: 1149|回复: 1
[Linux] OK3568休眠后不能唤醒
RK3568通行证
lixianglexus 发表于 2025-12-19 14:49:53 | 显示全部楼层 |阅读模式
群主您好,我按照手册说明,按下power键可以休眠,但是再按一下不能唤醒。只打印红框中内容,没有例子那么全的日志输出。
RK3568通行证
楼主| lixianglexus 发表于 2025-12-19 14:51:21 | 显示全部楼层
[root@ok3568:/]#  [  146.005510] PM: suspend entry 2019-01-01 00:02:23.751546568 UTC
[  146.006082] PM: Syncing filesystems ... done.
[  146.010583] Freezing user space processes ... (elapsed 0.002 seconds) done.
[  146.014178] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[  146.016954] Suspending console(s) (use no_console_suspend to debug)
只有以上部分打印出来[root@ok3568:/]#  [  146.005510] PM: suspend entry 2019-01-01 00:02:23.751546568 UTC
INFO:    sleep mode config[0xde]:
INFO:           AP_PWROFF
INFO:           SLP_ARMPD
INFO:           SLP_PLLPD
INFO:           DDR_RET
INFO:           SLP_CENTER_PD
INFO:    wakeup source config[0x804]:
INFO:           GPIO interrupt can wakeup system
INFO:           PWM interrupt can wakeup system
INFO:    PWM CONFIG[0x4]:
INFO:           PWM: PWM2D_REGULATOR_EN
INFO:    APIOS info[0x0]:
INFO:           not config
INFO:    GPIO POWER INFO:
INFO:           GPIO1_C1
INFO:           GPIO1_B6
INFO:    PMU_MODE_CONG: 0x1477bf51
这是完整的
