FCU2201修改5G网口名称
2023-6-16 09:21| 发布者: hai| 查看: 631| 评论: 0|原作者: hai
类目: LS1012A/LS1043A/LS1046A系列产品  >  Ubuntu     文档编号: 1021
1.查看网口IP(本次以usb0为例)
  root@localhost:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN mode DEFAULT group default qlen 1000
  link/sit 0.0.0.0 brd 0.0.0.0
3: usb0: <NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
  link/ether 02:50:f4:00:00:00 brd ff:ff:ff:ff:ff:ff
4: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
  link/ether 0e:55:3a:cc:05:be brd ff:ff:ff:ff:ff:ff
5: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br0 state DOWN mode DEFAULT group default qlen 1000
  link/ether 3a:63:01:e2:10:b5 brd ff:ff:ff:ff:ff:ff
6: br0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
  link/ether 06:e5:0a:f4:cb:44 brd ff:ff:ff:ff:ff:ff
7: lxcbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
  link/ether 00:16:3e:00:00:00 brd ff:ff:ff:ff:ff:ff
8: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
  link/ether 52:54:00:ef:a1:22 brd ff:ff:ff:ff:ff:ff
9: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast master virbr0 state DOWN mode DEFAULT group default qlen 1000
可以看到usb0网口的MAC为:02:50:f4:00:00:00
2.创建文件夹/etc/udev/rules.d/70-persistent-net.rules
vim /etc/udev/rules.d/70-persistent-net.rules
文件内容:
# Realtek 8211CU Wifi AC 0bda:c811
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="02:50:f4:00:00:00", NAME="wlan1"
3.重新启动板卡查看效果
  root@localhost:~# ifconfig
br0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      inet6 fe80::4e5:aff:fef4:cb44 prefixlen 64 scopeid 0x20<link>
      ether 06:e5:0a:f4:cb:44 txqueuelen 1000 (Ethernet)
      RX packets 0 bytes 0 (0.0 B)
      RX errors 0 dropped 0 overruns 0 frame 0
      TX packets 6 bytes 516 (516.0 B)
      TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      inet6 fe80::c55:3aff:fecc:5be prefixlen 64 scopeid 0x20<link>
      ether 0e:55:3a:cc:05:be txqueuelen 1000 (Ethernet)
eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      ether 3a:63:01:e2:10:b5 txqueuelen 1000 (Ethernet)
      TX packets 5 bytes 426 (426.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
      inet 127.0.0.1 netmask 255.0.0.0
      inet6 ::1 prefixlen 128 scopeid 0x10<host>
      loop txqueuelen 1000 (Local Loopback)
      RX packets 6 bytes 318 (318.0 B)
      TX packets 6 bytes 318 (318.0 B)
lxcbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      inet 10.0.3.1 netmask 255.255.255.0 broadcast 0.0.0.0
      ether 00:16:3e:00:00:00 txqueuelen 1000 (Ethernet)
      TX packets 0 bytes 0 (0.0 B)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
      inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
      ether 52:54:00:ef:a1:22 txqueuelen 1000 (Ethernet)
wlan1: flags=193<UP,RUNNING,NOARP> mtu 1500
      inet 10.135.10.144 netmask 255.255.255.224
      inet6 fe80::50:f4ff:fe00:0 prefixlen 64 scopeid 0x20<link>
      ether 02:50:f4:00:00:00 txqueuelen 1000 (Ethernet)
      RX packets 1 bytes 321 (321.0 B)
      TX packets 4 bytes 544 (544.0 B)
