8mm安卓添加rfkill功能
2023-9-25 10:20| 发布者: w_y_y| 查看: 512| 评论: 0
类目: 知识库  >  i.MX8MM系列产品     文档编号: 1130
1:在设备树中添加一下节点
bt_rfkill {
compatible = "fsl,mxc_bt_rfkill";
bt-power-gpios = <gpio2 6 GPIO ACTIVE LOW>;
status ="okay":
2:将引用到gpio2 IO06的节点注释掉
/*modem_reset: modem-reset {
                compatible = "gpio-reset";
                reset-gpios = <&gpio2 6 GPIO_ACTIVE_LOW>;
                reset-delay-us = <2000>;
                reset-post-delay-ms = <40>;
                #reset-cells = <0>;
3:修改驱动配置文件
打开文件:OK8MM-android-source/vendor/nxp-opensource/kernel_imx/arch/arm64/configs/android_defconfig
添加驱动配置
修改如下:
CONFIG_MACH_IMX_BLUETOOTH_RFKILL=y
4:重新编译烧写。启动后内核打印信息如下:
evk 8mm:/ # dmesg  grep rfkill
[   2.232094]   rfkill: BT RF going to : on
[   2.235946]  mxc bt rfkill reset
[   2.236440]  mxc bt rfkill driver success loaded
