335xd添加按键
2018-5-22 11:09| 发布者: 飞凌-chongzi| 查看: 3505| 评论: 0
类目: AM335x系列产品  >  Linux     文档编号: 185
目前有客户咨询335x系列的开发板上的按键设备名keypad是怎样生成的,因为在内核驱动中找不到相对应的名字。
在内核中按键的名字使用的是gpio-keys,然后在文件系统中进行了一个系统连接名字就变成了keypad.
具体的文件是/etc/udev/rules.d/local.rules文件
该文件中的以下语句就是生成keypad的链接命令
# Create a symlink to any gpio-keys input device
SUBSYSTEM=="input", KERNEL=="event[0-9]*", ATTRS{name}=="gpio-keys", SYMLINK+="input/keypad"
335按键添加方法
arch/arm/mach-omap2/board-am335xevm.c
static struct pinmux_config gpio_keys_pin_mux_forlinx[] = {
#if defined(CONFIG_OK335XD)
    {"gpmc_a4.gpio1_20", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_a5.gpio1_21", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_a6.gpio1_22", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_a7.gpio1_23", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_a8.gpio1_24", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_a9.gpio1_25", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
#elif defined(CONFIG_OK335XS)
    {"xdma_event_intr0.gpio0_19", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_csn3.gpio2_0", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"mcasp0_fsx.gpio3_15", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"gpmc_csn1.gpio1_30", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
    {"mcasp0_aclkx.gpio3_14", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
#elif defined(CONFIG_OK335XS2)
#endif
    {NULL, 0},
++此处添加自己按键的pinmux定义++
{"gpmc_a10.gpio1_26", OMAP_MUX_MODE7 | AM33XX_PIN_INPUT},
static void keys_init(int evm_id, int profile)
        int err;
        setup_pin_mux(gpio_keys_pin_mux_forlinx);
        err = platform_device_register(&am335x_evm_gpio_keys_forlinx);
    if (err)
        pr_err("failed to register gpio key device\n");
static struct platform_device am335x_evm_gpio_keys_forlinx = {
        .name   = "gpio-keys",
        .id     = -1,
        .dev    = {
                .platform_data  = &am335x_evm_gpio_key_info_forlinx,
static struct gpio_keys_platform_data am335x_evm_gpio_key_info_forlinx = {
        .buttons        = am335x_evm_gpio_buttons_forlinx,
        .nbuttons       = ARRAY_SIZE(am335x_evm_gpio_buttons_forlinx),
static struct gpio_keys_button am335x_evm_gpio_buttons_forlinx[] = {
                .code                   = BTN_0,
                .gpio                   = GPIO_TO_PIN(1, 20),
                .desc                   = "SW1",
                .code                   = BTN_1,
                .gpio                   = GPIO_TO_PIN(1, 21),
                .desc                   = "SW2",
                .code                   = BTN_2,
                .gpio                   = GPIO_TO_PIN(1, 22),
                .desc                   = "SW3",
                .wakeup                 = 1,
                .code                   = BTN_3,
                .gpio                   = GPIO_TO_PIN(1, 23),
                .desc                   = "SW4",
                .code                   = BTN_4,
                .gpio                   = GPIO_TO_PIN(1, 24),
                .desc                   = "SW5",
                .wakeup                 = 1,
                .code                   = BTN_5,
                .gpio                   = GPIO_TO_PIN(1, 25),
                .desc                   = "SW6",
++此处添加自己gpio对应按键定义++
                .code                   = BTN_6,
                .gpio                   = GPIO_TO_PIN(1, 26),
                .desc                   = "SW7",
                .code                   = BTN_0,
                .gpio                   = GPIO_TO_PIN(0, 19),
                .desc                   = "SW1",
                .code                   = BTN_1,
                .gpio                   = GPIO_TO_PIN(2, 0),
                .desc                   = "SW2",
                .code                   = BTN_2,
                .gpio                   = GPIO_TO_PIN(3, 15),
                .desc                   = "SW3",
                .wakeup                 = 1,
                .code                   = BTN_3,
                .gpio                   = GPIO_TO_PIN(1, 30),
                .desc                   = "SW4",
                .code                   = BTN_4,
                .gpio                   = GPIO_TO_PIN(3, 14),
                .desc                   = "SW5",
                .wakeup                 = 1,
                .code                   = BTN_0,
                .desc                   = "SW1",
                .code                   = BTN_1,
                .desc                   = "SW2",
                .code                   = BTN_2,
                .desc                   = "SW3",
                .wakeup                 = 1,
#endif
至此按键添加完毕,但事情是否做完了呢,还没有,我们用到了gpmc_a10这个管脚,需要将其他用到这个引脚的地方注释掉,保证没有其他功能占用
检测了一下gpmc_a10这个脚有一些其他的pinmux定义,但是都没完成初始化,不会产生影响
ps:
                .code                   = BTN_0,
                .desc                   = "SW1",
这个BTN_0指的是什么呢,这需要看一下include/linux/input.h,这里定义了按键的键值
