查看: 6604|回复: 3
请问如何更改FLASH分区大小?
memory832 该用户已被删除
memory832 发表于 2011-11-7 16:13:44 | 显示全部楼层 |阅读模式
飞凌-alexlee 发表于 2011-11-7 16:52:51 | 显示全部楼层
====================LINUX============================
LINUX分区表改为:(/arch/arm/mach-s3c2410/devs.c)
struct mtd_partition TE24xx_default_nand_part_b[]= {
        [0] = {
                .name   = "Boot",
                .size   = 0x00100000,
                .offset = 0
        [1] = {
                .name   = "MyApp",
                .size   = 0x003c0000,
                .offset = 0x00140000,
        [2] = {
                .name   = "Kernel",
                .size   = 0x00300000,
                .offset = 0x00500000,
        [3] = {
                .name   = "fs_yaffs",
                .size   = 0x07800000,    //原为60M现大小增大一倍
                .offset = 0x00800000,
/*      [4] = {
                .name   = "WINCE",
                .size   = 0x03c00000,
                .offset = 0x04400000,          //将wince屏蔽掉
struct s3c2410_nand_set nandset ={
nr_partitions: 4 ,               //原为5现改为4
partitions: TE24xx_default_nand_part_b,  //partition_info 64M
然后重新编译内核
boot源码中将nand.c中改为如下所示
static struct Partition NandPart[] = {
        {0,                          0x00100000, "boot"},                //128K
        {0x00100000, 0x00040000, "bootParam"},//two blocks
        {0x00140000, 0x003c0000, "MyApp"},                //4M512K
        {0x00500000, 0x00300000, "kernel"},                //3M128K
        //{0x00800000, 0x01400000, "fs_cramfs"},        //20M
        {0x00800000, 0x07800000, "fs_yaffs"},        //40M
//        {0x00500000, 0x03c00000, "wince"},                //60M
        {0,                         0         , 0}
然后重新编译boot即可
memory832 该用户已被删除
楼主| memory832 发表于 2011-11-7 21:39:59 | 显示全部楼层
飞凌-alexlee 发表于 2011-11-8 08:15:15 | 显示全部楼层
:P
