查看: 8288|回复: 6
咋回事“u-boot.bin error found: 0010”?
潇毅 发表于 2011-12-10 19:19:00 | 显示全部楼层 |阅读模式
  1. U-Boot 1.1.6 (Mar 23 2011 - 15:19:29) for SMDK6410
  2. ****************************************
  3. **    u-boot 1.1.6                    **
  4. **    Updated for TE6410 Board        **
  5. **    Version 1.0 (10-01-15)          **
  6. **    OEM: Forlinx Embedded           **
  7. **    Web: http://www.witech.com.cn   **
  8. ****************************************
  9. CPU:     S3C6410 @532MHz
  10.          Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode)
  11. Board:   SMDK6410
  12. DRAM:    128 MB
  13. Flash:   0 kB
  14. NAND:    tmp = 29
  15. select s3c_nand_oob_mlc_128
  16. 2048 MB
  17. SD/MMC:  1883 MB
  18. *** Warning - bad CRC or moviNAND, using default environment
  19. In:      serial
  20. Out:     serial
  21. Err:     serial
  22. Hit any key to stop autoboot:  0
  23. NAND erase: device 0 whole chip
  24. Erasing at 0x0 --   0
  25. Erasing at 0x1400000 --   1
  26. Erasing at 0x2880000 --   2
  27. Erasing at 0x3d00000 --   3mplete.
  28. Erasing at 0x5180000 --   4
  29. Erasing at 0x6600000 --   5
  30. Erasing at 0x7a80000 --   6
  31. Erasing at 0x8f00000 --   7
  32. Erasing at 0xa380000 --   8
  33. Erasing at 0xb800000 --   9
  34. Erasing at 0xcc80000 --  10mplete.
  35. Erasing at 0xe100000 --  11
  36. Erasing at 0xf580000 --  12
  37. Erasing at 0x10a00000 --  13
  38. Erasing at 0x13300000 --  15
  39. Erasing at 0x14780000 --  16
  40. Erasing at 0x15c00000 --  17
  41. Erasing at 0x17080000 --  18
  42. Erasing at 0x18500000 --  19 at 0x19980000 --  20
  43. Erasing at 0x1ae00000 --  21
  44. Erasing at 0x1c280000 --  22
  45. Erasing at 0x1d700000 --  23
  46. Erasing at 0x1eb80000 --  24
  47. Erasing at 0x1ff80000 --  25
  48. Erasing at 0x21400000 --  26
  49. Erasing at 0x22880000 --  27
  50. Erasing at 0x23d00000 --  28
  51. Erasing at 0x25180000 --  29
  52. Erasing at 0x26600000 --  30
  53. Erasing at 0x27a80000 --  31
  54. Erasing at 0x28f00000 --  32
  55. Erasing at 0x2a380000 --  33
  56. Erasing at 0x2b800000 --  34
  57. Erasing at 0x2cc80000 --  35
  58. Erasing at 0x2e100000 --  36
  59. Erasing at 0x2f580000 --  37
  60. Erasing at 0x30a00000 --  38 at 0x31e80000 --  39300000 --  40
  61. Erasing at 0x34780000 --  41
  62. Erasing at 0x35c00000 --  42
  63. Erasing at 0x37080000 --  43
  64. Erasing at 0x38500000 --  44
  65. Erasing at 0x39980000 --  45
  66. Erasing at 0x3ae00000 --  46 at 0x3c280000 --  47-  48
  67. Erasing at 0x3eb80000 --  49
  68. Erasing at 0x3ff80000 --  50400000 --  51-  52
  69. Erasing at 0x43d00000 --  53
  70. Erasing at 0x45180000 --  54
  71. Erasing at 0x46600000 --  55
  72. Erasing at 0x47a80000 --  56
  73. Erasing at 0x48f00000 --  57
  74. Erasing at 0x4a380000 --  58
  75. Erasing at 0x4b800000 --  59
  76. Erasing at 0x4cc80000 --  60
  77. Erasing at 0x4e100000 --  61
  78. Erasing at 0x4f580000 --  62
  79. Erasing at 0x50a00000 --  63
  80. Erasing at 0x51e80000 --  64 at 0x53300000 --  65
  81. Erasing at 0x55c00000 --  67omplete.
  82. Erasing at 0x57080000 --  68
  83. Erasing at 0x58500000 --  69
  84. Erasing at 0x59980000 --  70
  85. Erasing at 0x5ae00000 --  71
  86. Erasing at 0x5c280000 --  72
  87. Erasing at 0x5d700000 --  73
  88. Erasing at 0x5eb80000 --  74
  89. Erasing at 0x5ff80000 --  75
  90. Erasing at 0x61400000 --  76880000 --  77
  91. Erasing at 0x65180000 --  79omplete.
  92. Erasing at 0x67a80000 --  81f00000 --  82
  93. Erasing at 0x6a380000 --  83
  94. Erasing at 0x6b800000 --  84
  95. Erasing at 0x6cc80000 --  85
  96. Erasing at 0x6f580000 --  87
  97. Erasing at 0x70a00000 --  88
  98. Erasing at 0x71e80000 --  89
  99. Erasing at 0x73300000 --  90
  100. Skipping bad block at  0x73e80000
  101. Erasing at 0x74780000 --  91omplete.
  102. Erasing at 0x77080000 --  93
  103. Erasing at 0x78500000 --  94
  104. Erasing at 0x79980000 --  95
  105. Erasing at 0x7ae00000 --  96
  106. Erasing at 0x7c280000 --  97
  107. Erasing at 0x7d700000 --  98
  108. Erasing at 0x7eb80000 --  99
  109. Erasing at 0x7ff80000 -- 100reading u-boot.bin
  110. error found: 0010
复制代码
飞凌-fatfish 发表于 2011-12-11 13:49:43 | 显示全部楼层
没有找到u-boot.bin文件。
看看是不是没有文件或者文件名不对
楼主| 潇毅 发表于 2011-12-13 14:32:27 | 显示全部楼层
试过了,我用的是飞凌的给的光盘里面的uboot 以前烧写是没有出现问题,最近不知咋回事?不过我烧写wince时候就没有该问题?
25
飞凌-fatfish 发表于 2011-12-13 16:53:14 | 显示全部楼层
重新试试烧写mmc.bin
楼主| 潇毅 发表于 2011-12-13 17:28:54 | 显示全部楼层
回复 4# 飞凌-fatfish
好吧,我试试再发帖吧!
vell001 该用户已被删除
vell001 发表于 2012-8-7 00:11:50 | 显示全部楼层
飞凌-chongzi 发表于 2012-8-7 08:45:52 | 显示全部楼层
你的是SD卡吗?换一个试试
