查看: 12241|回复: 0
[Linux] ok6410a linux3.0.1( 飞凌提供)一键烧写出现如下错误?
96
52mcu 发表于 2015-1-3 23:19:09 | 显示全部楼层 |阅读模式
用飞凌提供的linux3.0.1等代码参照用户手册编译出u-boot.bin zImage  rootfs.yaffs2 等文件,然后一键烧写出现如下问题,
而使用飞凌提供的编译好的印象则没问题,为啥子,求帮助!
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NandFlash Information:
Nandflash:ChipType= MLC  ChipName=samsung-K9GAG08U0D
No  No Calc pagesize, blocksize, erasesize,  use ids table .............
NandFlash:name=NAND 2GiB 3,3V 8-bit,id=d5, pagesize=4096 ,chipsize=2048 MB,erasesize=524288 oobsize=128
NandFlash Size is 2048 MB
SD/MMC:  SD 2.0 SDHC / Manufacturer: 0x02,OEM: "TM/SA08G",REV: 1.3,S/N: 270391936,DATE: 2013/11
         SDHC size: 7384 MiB
         Freq = 50MHz
In:      serial
Out:     lcd
Err:     lcd
NAND erase: device 0 whole chip
Erasing at 0x7ff80000 -- 100% complete.
OK
reading u-boot.bin
212992 bytes read
NAND write: device 0 offset 0x0, size 0x200000
1032192 bytes written: OK
** Unable to read "logo.bmp" from mmc 0:1 **
