- 34
贡献16
飞刀2 FD
注册时间2016-5-6
在线时间32 小时
:handshake 自己修改linux-2.6.36.2的源码移植在OK6410上,运行开发板的情况:(其中UBOOT和根文件系统都是飞凌光盘上提供所对应2.6.36.2的)
TCP cubic registered
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
s3c-rtc s3c64xx-rtc: setting system clock to 2011-11-13 10:54:35 UTC (1321181675)
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 160K
/etc/rc.d/init.d/netd: line 16: /usr/sbin/inetd: not found
mkdir: cannot create directory '/mnt/disk': File exists
mount: mounting /dev/mtdblock3 on /mnt/disk failed: No such device
Try to bring eth0 interface up......ifconfig: SIOCGIFFLAGS: No such device
ifconfig: SIOCSIFHWADDR: No such device
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: Network is unreachable
Done
Starting Qtopia2, please waiting...
Please press Enter to activate this console. mouse...
cat: can't open '/sys/class/graphics/fb0/virtual_size': No such file or directory
mkdir: cannot create directory '/mnt/disk/QtopiaHome': Read-only file system
mkdir: cannot create directory '/mnt/disk/QtopiaHome/': Read-only file system
cp: cannot create '/mnt/disk/QtopiaHome/Settings/Trolltech/qpe.conf': No such file or directory
ln: /mnt/disk/QtopiaHome/Documents: No such file or directory
无法启动QT,输入Qtopia可以进入liunx
请问各位大侠这出了什么问题?
先谢谢了! |
