- 34
贡献16
飞刀2 FD
注册时间2016-5-6
在线时间32 小时
应该是内核移植的问题,开始我是怀疑没加LCD驱动才这样,现在我把DM9000和LCD的驱动也加进去了,但是还是如此情况,版主有没有好的建议?
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200 init=/linuxrc
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 122152k/122152k available, 8920k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xc8800000 - 0xe0000000 ( 376 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0031000 ( 164 kB)
.text : 0xc0031000 - 0xc0672000 (6404 kB)
.data : 0xc06cc000 - 0xc0715500 ( 294 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
s3c64xx_dma_init1: registering DMA 0 (c8808100)
s3c64xx_dma_init1: registering DMA 1 (c8808120)
s3c64xx_dma_init1: registering DMA 2 (c8808140)
s3c64xx_dma_init1: registering DMA 3 (c8808160)
s3c64xx_dma_init1: registering DMA 4 (c8808180)
s3c64xx_dma_init1: registering DMA 5 (c88081a0)
s3c64xx_dma_init1: registering DMA 6 (c88081c0)
s3c64xx_dma_init1: registering DMA 7 (c88081e0)
PL080: IRQ 73, at c8808000
s3c64xx_dma_init1: registering DMA 8 (c880c100)
s3c64xx_dma_init1: registering DMA 9 (c880c120)
s3c64xx_dma_init1: registering DMA 10 (c880c140)
s3c64xx_dma_init1: registering DMA 11 (c880c160)
s3c64xx_dma_init1: registering DMA 12 (c880c180)
s3c64xx_dma_init1: registering DMA 13 (c880c1a0)
s3c64xx_dma_init1: registering DMA 14 (c880c1c0)
s3c64xx_dma_init1: registering DMA 15 (c880c1e0)
PL080: IRQ 74, at c880c000
bio: create slab <bio-0> at 0
SCSI subsystem initialized
s3c-i2c s3c2440-i2c.1: no platform data
s3c-i2c: probe of s3c2440-i2c.1 failed with error -22
Advanced Linux Sound Architecture Driver Version 1.0.23.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 238
io scheduler noop registered |
