查看: 3785|回复: 2
视频压缩无线传输后,解码出现错误,求解答!
18
河谷吉他 发表于 2012-3-26 15:10:17 | 显示全部楼层 |阅读模式
我用的是OK6410,linux2.6.28内核,在server端采集视频,用h.264硬件压缩后,无线传输到client端,client端硬件解压时出现如下错误,求解答!
[root@OK6410 /tmp]# ./client_arm 192.168.0.10
[10. Camera preview & MFC encoding/decoding]
Forlinx Embedded, v0.1
Using IP            : MFC, Post processor, LCD, Camera
Camera preview size : 240x272
Display size        : 480x272
x : Exit
Select ==> Connect Server@192.168.0.10
recv: type is v,        rsize:6140,     frame_number:1, 1
s3c_mfc_inst_init_dec: sequence init failed
[APPLICATIONS: ERROR] mfc_decoder_init: H.264 Decoder Configuration Failed.
[APPLICATIONS: ERROR] SsbSipH264DecodeGetInBuf: openHandle is NULL
[APPLICATIONS: ERROR] mfc_decoder_exe: SsbSipH264DecodeGetInBuf Failed.
[APPLICATIONS: ERROR] SsbSipH264DecodeDeInit: openHandle is NULL
queue[0].size:6128
recv: type is v,        rsize:1526,     frame_number:2, 2
queue[1].size:1514
hjk_86297609 该用户已被删除
hjk_86297609 发表于 2012-3-26 15:14:51 | 显示全部楼层
默默地咆哮 该用户已被删除
默默地咆哮 发表于 2012-3-27 14:41:43 | 显示全部楼层
