查看: 14819|回复: 1
[已解决] OK2440-iii启动引导选项和说明书里面完全不一样
每天一小练 发表于 2010-1-12 08:41:57 | 显示全部楼层 |阅读模式
我刚刚买了快OK2440-III按照说明书上面操作不过引导选项和说明书里面完全不一样。请指教
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Dec 12
2007 18:04:21
Microsoft Windows CE Bootloader for the S
2 2007
FMD: ReadID (Mfg=ec, Dev=f1)
FMD_Init: finished successful
FMD_Init: reserved_blocks 548
FMD_GetInfo
Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot mon
itor.
Initiating image launch in 2 seconds.
Ethernet Boot Loader Configuration:
0) IP address: 192.168.1.115
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
4) Reset to factory default configuration
5) Startup image: LAUNCH EXISTING
6) Program disk image into SmartMedia card: Enabled
7) Program CS8900 MAC address (00:11:22:33:44:55)
8) Kernel Debugger: DISABLED
9) Format Boot Media for BinFS
F) Low-level format the Smart Media card
D) Download image now
L) LAUNCH existing Boot Media image
U) DOWNLOAD image now(USB)
R) Read Configuration
W) Write Configuration Right Now
Enter your selection:
飞凌-fatfish 发表于 2010-1-12 15:28:11 | 显示全部楼层
你好 ,这是eboot的启动信息,没看到什么问题。可能你看到的是手册里面的bootloader的信息。这两个是不一样的。
