- 2
贡献0
飞刀0 FD
注册时间2011-1-11
在线时间0 小时
回复 3# 小小
还是不行,这是串口反应。
Ethernet Boot Loader Configuration:
0) IP address: 0.0.0.0
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 5 seconds
4) Reset to factory default configuration
5) Startup image: LAUNCH EXISTING
6) Program disk image into SmartMedia card: Enabled
7) Program DM9000A MAC address (00:00:00:00:00:00)
8) KITL Configuration: DISABLED
9) Format Boot Media for BinFS
A) Erase All Blocks
B) Mark Bad Block at Reserved Block
C) Clean Boot Option: FALSE
D) Download image now
E) Erase Reserved Block
F) Low-level format the Smart Media card
L) LAUNCH existing Boot Media image
R) Read Configuration
S) Lcd Resolution select(480x272)
U) DOWNLOAD image now(USB)
W) Write Configuration Right Now
Enter your selection: f
Reserving Blocks [0x0 - 0x3] ...
...reserve complete.
Low-level format Blocks [0x4 - 0xfff] ...
LB######## Error Erasing block 2156!
LB######## Error Erasing block 2158!
...erase complete.
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: 9
Enter LowLevelFormat [0x4, 0xfff].
Erasing flash block(s) [0x4, 0xfff] (please wait): EraseBlocks: found a bad block (0x86c) - skipping...
EraseBlocks: found a bad block (0x86e) - skipping...
Done.
WriteMBR: MBR block = 0x4.
Done.
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: w
Successfully Written
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: u
System ready!
Preparing for download...
INFO: *** Device Name 'SMDK64100' ***
Please send the Image through USB.
BL_IMAGE_TYPE_BIN
Download BIN file information:
[0]: Base Address=0x80150000 Length=0x2311184
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x2311184, LaunchAddr = 0x80157734
Completed file(s):
[0]: Address=0x80150000 Length=0x2311184 Name="" Target=RAM
ROMHDR at Address 80150044h
TOC {
dwSignature: 0x434F544E
BootCfg {
ConfigFlags: 0x20830
BootDelay: 0x5
ImageIndex: 1
IP: 0.0.0.0
MAC Address: 00:00:00:00:00:00
Port: 0.0.0.0
SubnetMask: 255.255.255.0
ID[0] {
dwVersion: 0x20004
dwSignature: 0x45424F54
String: 'eboot.nb0'
dwImageType: 0x2
dwTtlSectors: 0x3C
dwLoadAddress: 0x80030000
dwJumpAddress: 0x800420F4
dwStoreOffset: 0x0
sgList[0].dwSector: 0x100
sgList[0].dwLength: 0x3C
ID[1] {
dwVersion: 0x1
dwSignature: 0x43465348
String: ''
dwImageType: 0x2
dwTtlSectors: 0x4623
dwLoadAddress: 0x80150000
dwJumpAddress: 0x80157734
dwStoreOffset: 0x0
sgList[0].dwSector: 0x480
sgList[0].dwLength: 0x4623
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x2311184, LaunchAddr:0x80157734
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 36770180
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: block = 0x3.
IsValidMBR: MBR sector = 0x200 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x7fc7f.
CreatePartition: Start = 0x280, Num = 0x4680.
Log2Phys: Logical 0x280 -> Physical 0x480
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updateded TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x4900 after processing part 0x21.
CreatePartition: Num sectors set to 0x7ae80 to allow for compaction blocks.
CreatePartition: Start = 0x4900, Num = 0x7ae80.
-WriteOSImageToBootMedia
waitforconnect
INFO: OEMLaunch: Jumping to Physical Address 0x50157734h (Virtual Address 0x80157734h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK : 133000000
[OAL] PCLK : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
+OALArgsInit()
Arguments area has some values
-OALArgsInit()
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 8 2010 13:24:59
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Aug 15 2010
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8003FEF4
INFO: (unsigned)ASM_IsrHandler : 0x800424DC
INFO: (unsigned)pISR : 0xEA01092F
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd3
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : PAGES_PER_BLOCK = 128
[FMD] FMD_Init() : SECTORS_PER_PAGE = 4
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 2048(0x800)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
EBOOT_FRAMEBUFFER_PA_START == 53800000
[Eboot] --InitializeDisplay()
Initiating image launch in 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
RAM image
RAM image
OpenPartition: Partition Exists=0x1 for part 0x21.
**[Eboot] BP_ReadData***
ReadData: Start = 0x0, Length = 0x2311800.
Loading Kernel......
System ready!
INFO: Using static IP address 0000.
INFO: Using subnet mask 2525250.
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
[OAL] ++OEMInit()
+OALArgsInit()
-OALArgsInit()
[OAL] --OEMInit() |
