查看: 4054|回复: 5
单系统boot的问题 寻找帮助
witedif 该用户已被删除
witedif 发表于 2011-7-31 11:22:51 | 显示全部楼层 |阅读模式
飞凌-alexlee 发表于 2011-8-1 08:15:23 | 显示全部楼层
====================LINUX============================
LINUX分区表改为:(/arch/arm/mach-s3c2410/devs.c)
struct mtd_partition TE24xx_default_nand_part_b[]= {
        [0] = {
                .name   = "Boot",
                .size   = 0x00100000,
                .offset = 0
        [1] = {
                .name   = "MyApp",
                .size   = 0x003c0000,
                .offset = 0x00140000,
        [2] = {
                .name   = "Kernel",
                .size   = 0x00300000,
                .offset = 0x00500000,
        [3] = {
                .name   = "fs_yaffs",
                .size   = 0x07800000,    //原为60M现大小增大一倍
                .offset = 0x00800000,
/*      [4] = {
                .name   = "WINCE",
                .size   = 0x03c00000,
                .offset = 0x04400000,          //将wince屏蔽掉
struct s3c2410_nand_set nandset ={
nr_partitions: 4 ,               //原为5现改为4
partitions: TE24xx_default_nand_part_b,  //partition_info 64M
然后重新编译内核
boot源码中将nand.c中改为如下所示
static struct Partition NandPart[] = {
        {0,                          0x00100000, "boot"},                //128K
        {0x00100000, 0x00040000, "bootParam"},//two blocks
        {0x00140000, 0x003c0000, "MyApp"},                //4M512K
        {0x00500000, 0x00300000, "kernel"},                //3M128K
        //{0x00800000, 0x01400000, "fs_cramfs"},        //20M
        {0x00800000, 0x07800000, "fs_yaffs"},        //40M
//        {0x00500000, 0x03c00000, "wince"},                //60M
        {0,                         0         , 0}
然后重新编译boot即可
witedif 该用户已被删除
楼主| witedif 发表于 2011-8-1 21:48:32 | 显示全部楼层
飞凌-alexlee 发表于 2011-8-2 08:13:07 | 显示全部楼层
该文件适合飞凌双系统的2440开发板,以下描述是将双系统修改为单系统的wince
1、boot中nand.c文件中
        {0,                          0x00100000, "boot"},        //1M
        {0x00100000, 0x00040000, "bootParam"},        //256K two blocks
        {0x00140000, 0x00100000, "pic"},                //1M
//        {0x00240000, 0x002c0000, "MyApp"},                //2M768K
//        {0x00500000, 0x00300000, "kernel"},                //3M
//        {0x00800000, 0x03c00000, "fs_yaffs"},        //60M
        {0x00240000, 0x07dc0000, "wince"},                //60M
        {0,                         0         , 0}
修改之后,将其重新编译。
注意,在下载新的单系统boot之前,最好用原双系统的boot将所有分区擦除(除boot分区),否则可能会出现用户可用flash比较小
2、修改nand flash驱动fmd.cpp文件
如果bsp为smdk2440,则该文件所在路径为E:\WINCE500\PLATFORM\smdk2440\DRIVERS\Nandflsh\FMD
如果bsp为smdk2440a,则该文件所在路径为:E:\WINCE500\PLATFORM\SMDK2440A\Src\Common\Smartmedia\Fmd
#if K9F1G08_SUPPORT
        {0xECF1,/*K9F1G08U0M*/
        FALSE,
        0x6700000,// 103M     修改改制可以修改为4600000,此时用户可用flash有50多兆,当然还可以再大些。
                {NAND,1024,2048*64,64,2048},
                FMD_ReadSector1G08,
                FMD_WriteSector1G08,
                FMD_EraseBlock1G08,
                IsBlockBad1G08,
                MarkBlockBad1G08
修改好之后编译下nand驱动即可,前提是工程已经编译过并选上了Make Run-Time Image After Build
witedif 该用户已被删除
楼主| witedif 发表于 2011-8-2 11:56:33 | 显示全部楼层
飞凌-alexlee 发表于 2011-8-2 13:14:14 | 显示全部楼层
对~
