- 36
贡献1
飞刀0 FD
注册时间2011-3-23
在线时间15 小时
各位高手,请教下。我烧写完成linux2.6.36.2后,运行就发现串口打印卡住了,希望指点,代码我用的是飞凌给的烧写代码。输出如下:
U-Boot 1.1.6 (Feb 24 2011 - 14:27:19) for SMDK6410
** u-boot 1.1.6 **
** Updated for TE6410 Board **
** Version 1.0 (10-01-15) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode
Board: SMDK6410
DRAM: 256 MB
Flash: 0 kB
NAND: select s3c_nand_oob_mlc_128
2048 MB
In: serial
Out: serial
Err: serial
s3c-nand: 1 bit(s) error detected, corrected successfully
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 2.6.36.2 (root@czj) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-7
2) ) #5 Fri Oct 28 16:56:10 CST 2011
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f9000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5edf9000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,11520
Memory: 256MB = 256MB total
Memory: 235584k/235584k available, 26560k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xe0000000 ( 248 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003c000 ( 208 kB)
.text : 0xc003c000 - 0xc04c4000 (4640 kB)
.data : 0xc0506000 - 0xc0546560 ( 258 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
s3c64xx_dma_init1: registering DMA 0 (d0808100)
s3c64xx_dma_init1: registering DMA 1 (d0808120)
s3c64xx_dma_init1: registering DMA 2 (d0808140)
s3c64xx_dma_init1: registering DMA 3 (d0808160)
s3c64xx_dma_init1: registering DMA 4 (d0808180)
s3c64xx_dma_init1: registering DMA 5 (d08081a0)
s3c64xx_dma_init1: registering DMA 6 (d08081c0)
s3c64xx_dma_init1: registering DMA 7 (d08081e0)
PL080: IRQ 73, at d0808000
s3c64xx_dma_init1: registering DMA 8 (d080c100)
s3c64xx_dma_init1: registering DMA 9 (d080c120)
s3c64xx_dma_init1: registering DMA 10 (d080c140)
s3c64xx_dma_init1: registering DMA 11 (d080c160)
s3c64xx_dma_init1: registering DMA 12 (d080c180)
s3c64xx_dma_init1: registering DMA 13 (d080c1a0)
s3c64xx_dma_init1: registering DMA 14 (d080c1c0)
s3c64xx_dma_init1: registering DMA 15 (d080c1e0)
PL080: IRQ 74, at d080c000
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.23.
msgmni has been set to 460
io scheduler noop registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
FB1: map_video_memory: dma=5e900000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
FB2: map_video_memory: dma=5e93fc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
Window[1] - FB1: map_video_memory: clear ff700000:0007f800
FB1: map_video_memory: dma=5e980000 cpu=ff700000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff73fc00:0003fc00
FB2: map_video_memory: dma=5e9bfc00 cpu=ff73fc00 size=0003fc00
fb1: s3cfb frame buffer device
Window[2] - FB1: map_video_memory: clear ff680000:0003fc00
FB1: map_video_memory: dma=5ea00000 cpu=ff680000 size=0003fc00
fb2: s3cfb frame buffer device
Window[3] - FB1: map_video_memory: clear ff780000:0003fc00
FB1: map_video_memory: dma=5ea40000 cpu=ff780000 size=0003fc00
fb3: s3cfb frame buffer device
jkq debug VIDCON0 is 353
leds initialized
pwm initialized
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
S3C NAND Driver, (c) 2008 Samsung Electronics
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
enter s3c64xx_setup_sdhci1_cfg_gpio
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=00008080
mmc0: new SD card at address aaaa
mmcblk0: mmc0:aaaa SD02G 1.84 GiB
mmcblk0: p1
Failed to reset WM9713: AC97 link error
ALSA device list:
No soundcards found.
s3c-rtc s3c64xx-rtc: hctosys: invalid date/time
mtd->size = 80000 blocks = 7800000
cheaking bad block...............
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 208K
停在这个地方就不动了的,好像是死机了的。请问是什么原因呢? |
