- 3
贡献25
飞刀2 FD
注册时间2019-11-30
在线时间0 小时
以下是Linux2.6.28的烧写问题:
U-Boot 1.1.6 (Dec 15 2010 - 09:02:39) for SMDK6410
** u-boot 1.1.6 **
** Updated for TE6410 Board **
** Version 1.0 (10-01-15) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Board: SMDK6410
DRAM: 128 MB
Flash: 0 kB
NAND: tmp = 29
select s3c_nand_oob_mlc_128
2048 MB
SD/MMC: 3782 MB (SDHC)
*** Warning - bad CRC or moviNAND, using default environment
In: serial
Out: serial
Err: serial
NAND erase: device 0 whole chip
Skipping bad block at 0x00000000
Skipping bad block at 0x00080000
Skipping bad block at 0x00100000
Erasing at 0x180000 -- 0
Erasing at 0x1400000 -- 1
Erasing at 0x2880000 -- 2
Erasing at 0x3d00000 -- 3
Erasing at 0x5180000 -- 4
Erasing at 0x6600000 -- 5
Erasing at 0x7a80000 -- 6
Erasing at 0x8f00000 -- 7
Erasing at 0xa380000 -- 8
Erasing at 0xb800000 -- 9te.
Erasing at 0xcc80000 -- 10
Erasing at 0xe100000 -- 11
Erasing at 0xf580000 -- 12
Erasing at 0x10a00000 -- 13.
Erasing at 0x11e80000 -- 14e.
Erasing at 0x13300000 -- 15
Erasing at 0x14780000 -- 16
Erasing at 0x15c00000 -- 17
Erasing at 0x17080000 -- 18
Erasing at 0x18500000 -- 19
Erasing at 0x19980000 -- 20
Erasing at 0x1ae00000 -- 21
Erasing at 0x1c280000 -- 22
Erasing at 0x1d700000 -- 23
Erasing at 0x1eb80000 -- 24
Skipping bad block at 0x1f480000
Erasing at 0x1ff80000 -- 25
Erasing at 0x21400000 -- 26
Erasing at 0x22880000 -- 27
Erasing at 0x23d00000 -- 28
Erasing at 0x25180000 -- 29
Erasing at 0x26600000 -- 30
Erasing at 0x27a80000 -- 31
Erasing at 0x28f00000 -- 32
Erasing at 0x2a380000 -- 33
Erasing at 0x2b800000 -- 34
Erasing at 0x2cc80000 -- 35
Erasing at 0x2e100000 -- 36
Erasing at 0x2f580000 -- 37
Erasing at 0x30a00000 -- 38
Erasing at 0x31e80000 -- 39
Erasing at 0x33300000 -- 40
Erasing at 0x34780000 -- 41
Erasing at 0x35c00000 -- 42
Erasing at 0x37080000 -- 43
Erasing at 0x38500000 -- 44
Erasing at 0x39980000 -- 45
Erasing at 0x3ae00000 -- 46
Erasing at 0x3c280000 -- 47
Erasing at 0x3d700000 -- 48plete.
Erasing at 0x3eb80000 -- 49te.
Erasing at 0x3ff80000 -- 50e.
Erasing at 0x41400000 -- 51mplete.
Erasing at 0x42880000 -- 52te.
Erasing at 0x43d00000 -- 53te.
Erasing at 0x45180000 -- 54.
Erasing at 0x46600000 -- 55.
Erasing at 0x47a80000 -- 56lete.
Erasing at 0x48f00000 -- 57
Erasing at 0x4a380000 -- 58ete.
Erasing at 0x4b800000 -- 59.
Erasing at 0x4cc80000 -- 60
Erasing at 0x4e100000 -- 61
Erasing at 0x4f580000 -- 62ete.
Erasing at 0x50a00000 -- 63.
Erasing at 0x51e80000 -- 64.
Erasing at 0x53300000 -- 65te.
Erasing at 0x54780000 -- 66
Erasing at 0x55c00000 -- 67lete.
Erasing at 0x57080000 -- 68
Erasing at 0x58500000 -- 69ete.
Erasing at 0x59980000 -- 70te.
Skipping bad block at 0x59b80000
Skipping bad block at 0x59c80000
Erasing at 0x5ae00000 -- 71
Erasing at 0x5c280000 -- 72ete.
Erasing at 0x5d700000 -- 73plete.
Erasing at 0x5eb80000 -- 74
Erasing at 0x5ff80000 -- 75te.
Skipping bad block at 0x61280000
Erasing at 0x61400000 -- 76
Erasing at 0x62880000 -- 77ete.
Erasing at 0x63d00000 -- 78mplete.
Erasing at 0x65180000 -- 79
Erasing at 0x66600000 -- 80 complete.
Erasing at 0x67a80000 -- 81 complete.
Erasing at 0x68f00000 -- 82omplete.
Erasing at 0x6a380000 -- 83
Erasing at 0x6b800000 -- 84complete.
Erasing at 0x6cc80000 -- 85omplete.
Erasing at 0x6e100000 -- 86complete.
Erasing at 0x6f580000 -- 87plete.
Erasing at 0x70a00000 -- 88te.
Erasing at 0x71e80000 -- 89
Erasing at 0x73300000 -- 90.
Erasing at 0x74780000 -- 91.
Erasing at 0x75c00000 -- 92
Erasing at 0x77080000 -- 93ete.
Erasing at 0x78500000 -- 94
Erasing at 0x79980000 -- 95
Erasing at 0x7ae00000 -- 96.
Erasing at 0x7c280000 -- 97
Erasing at 0x7d700000 -- 98plete.
Erasing at 0x7eb80000 -- 99
Erasing at 0x7ff80000 -- 100
reading u-boot.bin
196608 bytes read
NAND write: device 0 offset 0x0, size 0x100000
1032192 bytes written: OK
reading zImage
2482064 bytes read
NAND write: device 0 offset 0x100000, size 0x300000
Bad block at 0x100000 in erase block from 0x100000 will be skipped
Writing data at 0x180000 -- 0.
Writing data at 0x187000 -- 1mplete.
/*发帖长度限制,故省略*/
Writing data at 0x461000 -- 96
Writing data at 0x468000 -- 97
Writing data at 0x470000 -- 98
Writing data at 0x478000 -- 99
Writing data at 0x47f000 -- 100complete.
3145728 bytes written: OK
reading cramfs
31301632 bytes read
NAND write: device 0 offset 0x400000, size 0x2000000
Writing data at 0x400000 -- 0
Writing data at 0x451000 -- 1te.
Writing data at 0x4a3000 -- 2
Writing data at 0x4f5000 -- 3
Writing data at 0x547000 -- 4
Writing data at 0x599000 -- 5
Writing data at 0x5eb000 -- 6
Writing data at 0x63d000 -- 7
Writing data at 0x68f000 -- 8
Writing data at 0x6e1000 -- 9
Writing data at 0x733000 -- 10plete.
Writing data at 0x785000 -- 11
Writing data at 0x7d7000 -- 12e.
Writing data at 0x828000 -- 13
Writing data at 0x87a000 -- 14
Writing data at 0x8cc000 -- 15te.
Writing data at 0x91e000 -- 16
Writing data at 0x970000 -- 17
Writing data at 0x9c2000 -- 18lete.
Writing data at 0xa14000 -- 19
Writing data at 0xa66000 -- 20
Writing data at 0xab8000 -- 21
Writing data at 0xb0a000 -- 22
Writing data at 0xb5c000 -- 23
Writing data at 0xbae000 -- 24
Writing data at 0xbff000 -- 25
Writing data at 0xc51000 -- 26
Writing data at 0xca3000 -- 27
Writing data at 0xcf5000 -- 28
Writing data at 0xd47000 -- 29
Writing data at 0xd99000 -- 30
Writing data at 0xdeb000 -- 31
Writing data at 0xe3d000 -- 32
Writing data at 0xe8f000 -- 33
Writing data at 0xee1000 -- 34
Writing data at 0xf33000 -- 35
Writing data at 0xf85000 -- 36
Writing data at 0xfd7000 -- 37
Writing data at 0x1028000 -- 38
Writing data at 0x107a000 -- 39.
Writing data at 0x10cc000 -- 40
Writing data at 0x111e000 -- 41
Writing data at 0x1170000 -- 42
Writing data at 0x11c2000 -- 43
Writing data at 0x1214000 -- 44
Writing data at 0x1266000 -- 45
Writing data at 0x12b8000 -- 46e.
Writing data at 0x130a000 -- 47
Writing data at 0x135c000 -- 48
Writing data at 0x13ae000 -- 49
Writing data at 0x13ff000 -- 50
Writing data at 0x1451000 -- 51
Writing data at 0x14a3000 -- 52.
Writing data at 0x14f5000 -- 53.
Writing data at 0x1547000 -- 54
Writing data at 0x1599000 -- 55
Writing data at 0x15eb000 -- 56
Writing data at 0x163d000 -- 57
Writing data at 0x168f000 -- 58
Writing data at 0x16e1000 -- 59
Writing data at 0x1733000 -- 60
Writing data at 0x1785000 -- 61plete.
Writing data at 0x17d7000 -- 62
Writing data at 0x1828000 -- 63
Writing data at 0x187a000 -- 64
Writing data at 0x18cc000 -- 65
Writing data at 0x191e000 -- 66
Writing data at 0x1970000 -- 67
Writing data at 0x19c2000 -- 68
Writing data at 0x1a14000 -- 69lete.
Writing data at 0x1a66000 -- 70
Writing data at 0x1ab8000 -- 71
Writing data at 0x1b0a000 -- 72
Writing data at 0x1b5c000 -- 73
Writing data at 0x1bae000 -- 74
Writing data at 0x1bff000 -- 75
Writing data at 0x1c51000 -- 76
Writing data at 0x1ca3000 -- 77.
Writing data at 0x1cf5000 -- 78
Writing data at 0x1d47000 -- 79
Writing data at 0x1d99000 -- 80complete.
Writing data at 0x1deb000 -- 81
Writing data at 0x1e3d000 -- 82e.
Writing data at 0x1e8f000 -- 83
Writing data at 0x1ee1000 -- 84
Writing data at 0x1f33000 -- 85
Writing data at 0x1f85000 -- 86
Writing data at 0x1fd7000 -- 87
Writing data at 0x2028000 -- 88
Writing data at 0x207a000 -- 89
Writing data at 0x20cc000 -- 90
Writing data at 0x211e000 -- 91
Writing data at 0x2170000 -- 92
Writing data at 0x21c2000 -- 93
Writing data at 0x2214000 -- 94
Writing data at 0x2266000 -- 95
Writing data at 0x22b8000 -- 96
Writing data at 0x230a000 -- 97
Writing data at 0x235c000 -- 98
Writing data at 0x23ae000 -- 99
Writing data at 0x23ff000 -- 10032 bytes written: OK
SMDK6410 #
系统烧到这里,显示是成功了的,但是启动系统时,屏没有显示,串口打印信息为:
SMDK6410 # K
重启系统后,又打印一个K
望Fatfish解决下,谢谢了! |
