查看: 8979|回复: 3
ubuntu 10.10下编译android源码出错
xzxxd 发表于 2012-1-15 12:40:45 | 显示全部楼层 |阅读模式
按照说明文档进行编译,但一直出现这个错误。求解。
including device/htc/passion/vendorsetup.sh
including device/samsung/crespo/vendorsetup.sh
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=2.3.4
TARGET_PRODUCT=OK6410
TARGET_BUILD_VARIANT=eng
TARGET_SIMULATOR=false
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
HOST_ARCH=x86
HOST_OS=linux
HOST_BUILD_TYPE=release
BUILD_ID=GRJ06D
Checking build tools versions...
find: `frameworks/base/frameworks/base/docs/html': 没有那个文件或目录
find: `out/target/common/docs/gen': 没有那个文件或目录
diff: out/target/product/OK6410/obj/PACKAGING/updater_extensions_intermediates/register.inc.list: 没有那个文件或目录
build/core/Makefile:21: 警告:覆盖关于目标“out/target/product/OK6410/root/init.rc”的命令
system/core/rootdir/Android.mk:38: 警告:忽略关于目标“out/target/product/OK6410/root/init.rc”的旧命令
host Java: apicheck (out/host/common/obj/JAVA_LIBRARIES/apicheck_intermediates/classes)
Header: out/host/linux-x86/obj/include/libexpat/expat.h
Header: out/host/linux-x86/obj/include/libexpat/expat_external.h
Header: out/target/product/OK6410/obj/include/libexpat/expat.h
Header: out/target/product/OK6410/obj/include/libexpat/expat_external.h
Header: out/host/linux-x86/obj/include/libpng/png.h
Header: out/host/linux-x86/obj/include/libpng/pngconf.h
Header: out/host/linux-x86/obj/include/libpng/pngusr.h
Header: out/target/product/OK6410/obj/include/libpng/png.h
Header: out/target/product/OK6410/obj/include/libpng/pngconf.h
Header: out/target/product/OK6410/obj/include/libpng/pngusr.h
Header: out/target/product/OK6410/obj/include/libwpa_client/wpa_ctrl.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas_types.h
Header: out/target/product/OK6410/obj/include/libsonivox/eas_reverb.h
Header: out/target/product/OK6410/obj/include/libsonivox/jet.h
Header: out/target/product/OK6410/obj/include/libsonivox/ARM_synth_constants_gnu.inc
host C: acp <= build/tools/acp/acp.c
host C++: libhost <= build/libs/host/pseudolocalize.cpp
/bin/bash: g++:找不到命令
make: *** [out/host/linux-x86/obj/STATIC_LIBRARIES/libhost_intermediates/pseudolocalize.o] 错误 127
楼主| xzxxd 发表于 2012-1-15 21:38:30 | 显示全部楼层
已解决,库文件没有安装好
飞凌-chongzi 发表于 2012-1-17 08:38:57 | 显示全部楼层
{:2_27:}
飞凌-chongzi 发表于 2012-1-17 08:39:03 | 显示全部楼层
{:2_27:}
