查看: 12152|回复: 8
重烧linux和yaffs文件系统之后问题,在线等,急!
jillm4a1 发表于 2010-6-19 16:49:01 | 显示全部楼层 |阅读模式
把flash整片擦除之后,重烧了2440boot.bin   Logo   zImage   qte_touch.yaffs   NK_320_240.bin
都是按照说明书上做的
但现在我启动linux之后,无法看到桌面了,停在了校准触摸屏那个地方,我校准了5个点之后,屏幕上仍然还是让我校准触摸屏,没有进入下一个环节
倒是可以通过串口输入命令
请问我该如何才能让我的板子正常运行(就像刚买来时那样,可以进入桌面)
串口打印的内容为:
楼主| jillm4a1 发表于 2010-6-19 16:49:40 | 显示全部楼层
Set boot params = root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320 0
Load Kernel...
Uncompressing Linux................................................................................................................... done, booting the kernel.
Linux version 2.6.12-h1940 (root@localhost.localdomain) (gcc version 3.4.1) #400 Fri Dec 5 12:16:19 CST 2008
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
S3C2440: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
Built 1 zonelists
Kernel command line: root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320 0
irq: clearing pending ext status 000dfe00
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00500d00, tcnt a2c1, tcfg 0000020f,00000030, usec 00001eb8
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 60800KB available (2966K code, 912K data, 160K init)
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 96.000 MHz
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
NTFS driver 2.1.22 [Flags: R/W].
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Nov  4 2008 17:54:45 Installing.
Initializing Cryptographic API
--- s3c2410fb init ---!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pxafb_probe start!!!!!!!!!!!!!!!!!!!!!!!!!!
VA=0xc4880000, PA=0x30600000, size=0x00027000
success to register framebuffer device: 0!!!
enable_irq(32) unbalanced from c0016ff4
done probe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
fb1: Virtual frame buffer device, using 1024K of video memory
in s3c2410ts init()
success get major number!!!!!!
s3c2410-ts device driver MAJOR:253
success to get adc clock source!
base_addr = 0xc4860000
line 543 passed!
register s3c2410-ts driver success, return code is 0
S3C2410 RTC, (c) 2004 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
hello,you have insert module that support MCP2510,to make
use of it, you must use: mknod /dev/can c 98 0,and you can
run test demo named 2510test for a test in loop back mode
you'll modify the driver to make it fall into normal mode
initialize ST16C550 on TE2440 board, iobase = 0xd4000000
Serial: 8250/16550 driver $Revision: 1.90 $ ,hace done serial8250_io_init!!!!5 ports, IRQ sharing disabled
have enter serial8250_isa_init_ports!iobase = 0xc4a00000
line 2166 passed
line 2168 passed
before uart_configure_port!
line 1958 passed
line 1960 passed
OUT!!line 1987 passed
after uart_configure_port!
line 2196 passed
line 2198 passed
line 2166 passed
line 2168 passed
line 1958 passed
line 1960 passed
IN!!line 1965 passed
enter uart_report_port() line 1918 passed
s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
line 1967 passed
line 1974 passed
line 1976 passed
line 2196 passed
line 2198 passed
line 2166 passed
line 2168 passed
line 1958 passed
line 1960 passed
s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
line 1967 passed
line 1974 passed
line 1976 passed
line 1984 passed
line 2196 passed
line 2198 passed
line 2166 passed
line 2168 passed
line 1958 passed
line 1960 passed
s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
line 1967 passed
line 1974 passed
line 1976 passed
line 1984 passed
line 2196 passed
line 2198 passed
楼主| jillm4a1 发表于 2010-6-19 16:51:12 | 显示全部楼层
io scheduler noop registered
io scheduler anticipatory registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
nbd: registered device at major 43
ub: sizeof ub_scsi_cmd 68 ub_dev 2384 ub_lun 140
usbcore: registered new driver ub
Cirrus Logic CS8900A driver for Linux (V0.02)
dev->base_addr=0xe0000300<3>line 689 passed,request_region() OK!success get IO port address!
eth0: incorrect signature 0x0000
dm9000 Ethernet Driver
eth0: dm9000 at c49b8300,c49ba304 IRQ 51 MAC: 00:12:34:56:80:49
STRIP: Version 1.3A-STUART.CHESHIRE (unlimited channels)
Linux video capture interface: v1.00
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
SET CF & IDE WAIT!now BWSCON=225dd510
-1:no 0:ok ide_register_hw return -1
block2mtd: version $Revision: 1.23 $
s3c2410-nand: mapped registers at c4b80000
s3c2410-nand: timing: Tacls 10ns, Twrph0 40ns, Twrph1 10ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Bad eraseblock 30 at 0x003c0000
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00100000 : "Boot"
0x00140000-0x00500000 : "MyApp"
0x00500000-0x00800000 : "Kernel"
0x00800000-0x04400000 : "fs_yaffs"
0x04400000-0x08000000 : "WINCE"
usbmon: debugs is not available
hello,enter new ohci-s3c2410.c
CLKDIVN = 0000000d
CLKSLOW = 00000004
CLKCON = 00f2e770
UPLLCON = 00038021
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.12-h1940 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usbcore: registered new driver usb-storage
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
pwc Philips webcam module version 9.0.2-unofficial loaded.
pwc Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
pwc the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
usbcore: registered new driver Philips webcam
usbcore: registered new driver gspca
drivers/usb/media/gspca/gspca_core.c: gspca driver 00.60.00 registered
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 390 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Bluetooth: HCI USB driver ver 2.8
usbcore: registered new driver hci_usb
hello,enter s3c2410sdi_probe()!!!!!!!!!!!!!!!!!!!!!!!!!
mmc->f_max =25000000
mmc->f_min =97656
mmci-s3c2410: probe: mapped sdi_base=c5000000 irq=37 irq_cd=62 dma=0.
mmci-s3c2410: initialisation done.
virtual address of s3c2410_va_iis=f0d00000.
next will do driver_register!
just enter s3c2410_uda1341_probe()
S3C2410-UDA1341 Probe
line 1314 passed! have set L3 mode=GPB2, dat=GPB3, clk=GPB4, output
line 1319 passed!
have set IISLRCK=GPE0, IISSCLK=GPE1, CDCLK=GPE2, IISSDI=GPE3, IISSDO=GPE4
line 1323 passed! have Enable IIS clock
success register irq: iisout_dma_done_handler
success register irq: iisin_dma_done_handler
UDA1341 audio driver initialized
driver uda1341 in /sound/oss/s3c2410-oss.c
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
Bluetooth: L2CAP ver 2.7
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM ver 1.5
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
yaffs: passed flags ""
yaffs: auto selecting yaffs2
VFS: Mounted root (yaffs filesystem).
Mounted devfs on /dev
Freeing init memory: 160K
init started: BusyBox v1.6.0 (2008-01-09 17:10:28 CST) multi-call binary
starting pid 381, tty '': '/etc/init.d/rcS'
mount: mounting tmpfs on /dev/shm failed
eth0: link down
ifconfig: SIOCSIFADDR: No such device
Please press Enter to activate this console. Could not read calibration: /etc/pointercal
Warning: Need to run firstuse
Warning: language message - en_US
Warning: and its not null
Warning: loading /usr/i18n/en_US/qt.qm
Warning: loading /usr/i18n/en_US/qpe.qm
Warning: loading /usr/i18n/en_US/libqpe.qm
Warning: loading /usr/i18n/en_US/libqtopia.qm
Warning: loading /usr/i18n/en_US/language.qm
Warning: loading /usr/i18n/en_US/timezone.qm
Warning: loading /usr/i18n/en_US/systemtime.qm
楼主| jillm4a1 发表于 2010-6-19 17:29:26 | 显示全部楼层
刚刚翻了一下旧帖子
发现有我这种问题的人很多啊
squire 发表于 2010-6-20 21:37:19 | 显示全部楼层
我也遇到过同样的问题,重烧了几次yaffs就又好了,至今莫名其妙中
同问
25
飞凌-fatfish 发表于 2010-6-21 09:08:12 | 显示全部楼层
是校准没通过
一种可能,校准方法不对,
另一种可能,如果是3.5寸屏的话,内核不合适。这种情况,在光盘linux2.6.12文件夹下有两个zImage:zImage1和zImage2;如果使用其中一个不能校准,就更换另外一个。具体原因见帖子
http://bbs.witech.com.cn/thread-53-1-1.html
飞凌-seventeen 发表于 2010-6-21 09:12:37 | 显示全部楼层
如果是校准过不去,肯定不是因为你的文件系统的问题。是你的zImage
建议如果重新烧写可以讲内核和文件系统分区先擦除。光盘上提供了2个zImage文件(触摸的区别),当校准过不去的时候,可以换另外的一个试试
郑茂茂 发表于 2010-6-21 10:03:07 | 显示全部楼层
试了下,貌似还是不行啊
25
飞凌-fatfish 发表于 2010-6-22 08:12:54 | 显示全部楼层
擦一下分区再烧写
