查看: 8662|回复: 4
ARM-qtopia-free-src-2.2.0出问题 错误:’ptrdiff_t’不是一个类型名
ljc710871968 发表于 2012-3-29 15:11:44 | 显示全部楼层 |阅读模式
  1. In file included from ../include/qmap.h:46:0,
  2.                  from kernel/qmime.h:43,
  3.                  from kernel/qevent.h:45,
  4.                  from kernel/qobject.h:45,
  5.                  from kernel/qwidget.h:43,
  6.                  from kernel/qdesktopwidget.h:40,
  7.                  from kernel/qapplication.h:42,
  8.                  from kernel/qapplication_x11.cpp:64:
  9. ../include/qvaluelist.h:88:13: 错误: ‘ptrdiff_t’不是一个类型名
  10. ../include/qvaluelist.h:164:13: 错误: ‘ptrdiff_t’不是一个类型名
  11. In file included from ../include/qmap.h:46:0,
  12.                  from kernel/qmime.h:43,
  13.                  from kernel/qevent.h:45,
  14.                  from kernel/qobject.h:45,
  15.                  from kernel/qwidget.h:43,
  16.                  from kernel/qdesktopwidget.h:40,
  17.                  from kernel/qapplication.h:42,
  18.                  from kernel/qapplication_x11.cpp:64:
  19. ../include/qvaluelist.h:424:13: 错误: ‘ptrdiff_t’不是一个类型名
  20. In file included from kernel/qmime.h:43:0,
  21.                  from kernel/qevent.h:45,
  22.                  from kernel/qobject.h:45,
  23.                  from kernel/qwidget.h:43,
  24.                  from kernel/qdesktopwidget.h:40,
  25.                  from kernel/qapplication.h:42,
  26.                  from kernel/qapplication_x11.cpp:64:
  27. ../include/qmap.h:107:13: 错误: ‘ptrdiff_t’不是一个类型名
  28. ../include/qmap.h:223:13: 错误: ‘ptrdiff_t’不是一个类型名
  29. In file included from kernel/qmime.h:43:0,
  30.                  from kernel/qevent.h:45,
  31.                  from kernel/qobject.h:45,
  32.                  from kernel/qwidget.h:43,
  33.                  from kernel/qdesktopwidget.h:40,
  34.                  from kernel/qapplication.h:42,
  35.                  from kernel/qapplication_x11.cpp:64:
  36. ../include/qmap.h:604:13: 错误: ‘ptrdiff_t’不是一个类型名
  37. kernel/qapplication_x11.cpp: 在成员函数‘int QApplication::x11ProcessEvent(XEvent*)’中:
  38. kernel/qapplication_x11.cpp:3690:54: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  39. kernel/qapplication_x11.cpp:3703:54: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  40. kernel/qapplication_x11.cpp: 在成员函数‘bool QETWidget::translateMouseEvent(const XEvent*)’中:
  41. kernel/qapplication_x11.cpp:4119:30: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  42. kernel/qapplication_x11.cpp: 在成员函数‘bool QETWidget::translateKeyEventInternal(const XEvent*, int&, QString&, int&, char&, int&, QEvent::Type&, bool)’中:
  43. kernel/qapplication_x11.cpp:5158:8: 警告: 建议显式地使用花括号以避免出现有歧义的‘else’ [-Wparentheses]
  44. kernel/qapplication_x11.cpp:5229:52: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  45. kernel/qapplication_x11.cpp:5232:52: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  46. kernel/qapplication_x11.cpp: 在函数‘int isPaintOrScrollDoneEvent(Display*, XEvent*, XPointer)’中:
  47. kernel/qapplication_x11.cpp:5521:34: 警告: 建议在‘||’的操作数中出现的‘&&’前后加上括号 [-Wparentheses]
  48. make[2]: *** [.obj/release-shared-mt/qapplication_x11.o] 错误 1
  49. make[2]:正在离开目录 `/usr/yizhi/qtopia-free-2.2.0/dqt/src'
  50. make[1]: *** [sub-src] 错误 2
  51. make[1]:正在离开目录 `/usr/yizhi/qtopia-free-2.2.0/dqt'
  52. * ---------------------------------------------------------------------------
  53. *
  54. *               ERROR: Building Qtopia Tools has failed.
  55. *
  56. * Please investigate the problem by looking at the error messages in the
  57. * make output.
  58. * The Qtopia tools can be build using the separate buildQtopiaTools script
  59. * which can be found in the qtopia/scripts directory of the package. The
  60. * script is also invoked with the command 'make tools' from the package root
  61. * directory.
  62. *
  63. * On most machines the default configuration options in the script works fine.
  64. * In case this doesn't work the configure parameters in the buildQtopiaTools
  65. * script need to be tweaked to fit the environment/compiler used on the machine
  66. * and then run manually from the cmd line.
  67. *
  68. * Please make sure that the following binaries exist before trying to build
  69. * Qtopia:
  70. *   /usr/yizhi/qtopia-free-2.2.0/qt2/bin/moc
  71. *   /usr/yizhi/qtopia-free-2.2.0/qt2/bin/uic
  72. *   /usr/yizhi/qtopia-free-2.2.0/qt2/bin/qvfb
  73. *   /usr/yizhi/qtopia-free-2.2.0/dqt/bin/lrelease
  74. *   /usr/yizhi/qtopia-free-2.2.0/dqt/bin/lupdate
  75. *
  76. * As a rule, these tools need to be built only once.
  77. *
  78. ******************************************************************************
复制代码
楼主| ljc710871968 发表于 2012-3-29 15:12:35 | 显示全部楼层
问了好几天,版主理都不理。。。。怎么在线支持
souljaven 该用户已被删除
souljaven 发表于 2012-3-29 17:33:54 | 显示全部楼层
wormking 该用户已被删除
wormking 发表于 2012-4-7 14:19:13 | 显示全部楼层
wanyanlingl 该用户已被删除
wanyanlingl 发表于 2012-4-13 12:55:43 | 显示全部楼层
