查看: 4539|回复: 5
qtopia4.4.3启动问题
14
zbj20082003 发表于 2012-5-2 09:33:23 | 显示全部楼层 |阅读模式
最近编译qtopia4.4.3按照百科全书上编译成功后,运行在开发板上,总是崩溃:
开发板的配置:128MRam 256MRom;Linux3.0.1;
将qtopia4.4.3制作在yaffs2中,yaffs2文件大小为116 MB,启动后依然崩溃,如下是崩溃后在超级终端上的最后的一些信息:
[<c01c8930>] (yaffs_file_rd+0xac/0x2f4) from [<c01c0b7c>] (yaffs_readpage_nolockin/dirname             /bin/msh                 /bin/top
+0x78/0x160)           m
[<c01c0b7c>] (yaffs_readpage_nolock+0x78/0x160) from [<c01c0e10>] (yaffs_readpag
7d
    vector  : 0xffff0
/bin/dos2unix            /bin/
e+0x30/0x74)       /bin/
[<c00da928>] (ondemand_readahead+0x128/0x220) from [<c00daac8>] (page_cache_asyn
c_readahead+0xa8/0xac)
[<c00daac8>] (page_cache_async_readahead+0xa8/0xac) from [<c00d22f8>] (filemap_f
ault+0x1f8/0x3ac)
[<c00d22f8>] (filemap_fault+0x1f8/0x3ac) from [<c00ece28>] (__do_fault+0x58/0x45
4)
[<c00ece28>] (__do_fault+0x58/0x454) from [<c00edc94>] (handle_pte_fault+0x8c/0x
6b4)
[<c00edc94>] (handle_pte_fault+0x8c/0x6b4) from [<c00ee774>] (handle_mm_fault+0x
ac/0xe4)
[<c00ee774>] (handle_mm_fault+0xac/0xe4) from [<c048925c>] (do_page_fault+0x268/
0x310)
[<c048925c>] (do_page_fault+0x268/0x310) from [<c00512fc>] (do_DataAbort+0x40/0x
a4)
[<c00512fc>] (do_DataAbort+0x40/0xa4) from [<c0487304>] (ret_from_exception+0x0/
0x10)
Exception stack(0xcbcfbfb0 to 0xcbcfbff8)
bfa0:                                     41939a59 00000024 41938ea0 00000bb9
bfc0: 00000024 00000000 41970598 400df074 00000000 400df000 01346b98 bef48c4c
bfe0: 80000000 bef48b70 400c673c 400d0118 20000010 ffffffff
Code: 059011d0 13a00000 e59c4210 e59111e8 (e5913210)
---[ end trace c933794ebd665679 ]---
Fixing recursive fault but reboot is needed!
版主有没有制作好的带有qtopia4.4.3的yaffs2文件系统,给发一个616000432@qq.com
楼主| zbj20082003 发表于 2012-5-2 17:12:24 | 显示全部楼层
一个问题,一天没人回答。电话中说的是网上贴出来解决,网上贴出来没人跟进。无语
飞凌-develop 发表于 2012-5-3 09:06:08 | 显示全部楼层
楼主:
我们提供的Yaffs2文件系统默认是没有Qtopia4.4.3的库文件的,但是我们提供好了可以运行的Qtopia4.4.3文件,位于光盘目录Linux-3.0.1\apptest\QT ApplicationTest\Qt-extended-4.4.3 目录下面,楼主可以去掉文件系统中不用的Qt库,比如Qtopia2.2.0,Qt4.7库文件,然后把我们提供的Qtopia4.4.3安装到文件系统的 /opt目录下面,烧写到开发板上,在超级终端里面执行Qtopia4命令即可。
14
楼主| zbj20082003 发表于 2012-5-3 13:15:57 | 显示全部楼层
首先非常感谢如此详尽的讲解!不管解决不解决问题,如此详尽的讲解应该受到表扬!也希望官方其他技术支持能都能够向这位技术支持学习!:)
14
楼主| zbj20082003 发表于 2012-5-3 13:53:21 | 显示全部楼层
按着版主给的方法问题解决了,久违的QT4终于呈现与眼前了,再次表示感谢!
飞凌-develop 发表于 2012-5-3 16:41:50 | 显示全部楼层
解决了就好,呵呵
