查看: 9367|回复: 1
用busybox自制文件系统, 在android kernel下启动, 无法正常启动
wyl_e 发表于 2010-11-12 23:16:31 | 显示全部楼层 |阅读模式
如题, 用busybox自制文件系统, 在android kernel下启动, 无法正常启动
BOOT参数如下:root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
出现以下错误:
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs_read_super: isCheckpointed 0
Freeing init memory: 140K
Warning: unable to open an initial console.
按照网上帖子的常用解决方法,
mknod -m 660 console c 5 1
mknod -m 660 null c 1 3
重新创建/dev/console /dev/null , 错误依旧.
文件系统配置如下:
bin  dev  etc  init  lib  linuxrc  mnt  proc  root  sbin  sys  tmp  usr
./bin:
addgroup  deluser        hostname  lsattr      pipe_progress  stty
adduser   df             hush      lzop        printenv       su
ash       dmesg          ionice    makemime    ps             sync
busybox   dnsdomainname  ip        mkdir       pwd            tar
cat       dumpkmap       ipaddr    mknod       reformime      touch
catv      echo           ipcalc    mktemp      rev            true
chattr    ed             iplink    more        rm             umount
chgrp     egrep          iproute   mount       rmdir          uname
chmod     false          iprule    mountpoint  rpm            usleep
chown     fdflush        iptunnel  mt          run-parts      vi
cp        fgrep          kill      mv          scriptreplay   watch
cpio      fsync          linux32   netstat     sed            zcat
cttyhack  getopt         linux64   nice        setarch
date      grep           ln        pidof       sh
dd        gunzip         login     ping        sleep
delgroup  gzip           ls        ping6       stat
./dev:
console  mtdblock0  mtdblock1  mtdblock2  null  ttySAC0
./etc:
fstab  init.d  inittab
./etc/init.d:
rcS
./lib:
...............................................略
./mnt:
./proc:
./root:
./sbin:
./sys:
./tmp:
./usr:
bin  sbin
./usr/bin:
./usr/sbin:
.................................................略
修改启动参数, 故意将root指向mtdblock3,则报出不一样的错误
VFS: Mounted root (yaffs2 filesystem) on device 31:3.
Failed to execute linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
对比上面的错误看, root指向mtdblock2时,init操作没有报错,好像是yaffs文件系统 已经被正确的识别了, 本人菜鸟 , 不确定, 还请大虾指教.
如果yaffs文件系统 被识别了, 我又多次重新mknod /dev/console /dev/null, 为什么还是报Warning: unable to open an initial console.的错误呢?
飞凌-alexlee 发表于 2010-11-13 12:34:56 | 显示全部楼层
console, mknod的时候参数是什么?
另外看一下boot传给kernel的参数
