- 3
贡献25
飞刀2 FD
注册时间2018-1-25
在线时间0 小时
按照linux用户手册上的“编译Uboot 编译内核”一章进行 做zImage,与uboot,然后 用光盘自带的 cramfs,一步一步,成功烧写了 系统(提示SMDK6410 #),
然后设置为nand 启动,信息如下: (nand 我已经用eboot 选A 察除过)
请问什么问题?检查坏快??请知道的朋友解释一下!谢谢
U-Boot 1.1.6 (Jan 20 2011 - 22:43:36) for SMDK6410
** u-boot 1.1.6 **
** Updated for TE6410 Board **
** Version 1.0 (10-01-15) **
** OEM: Forlinx Embedded **
** Web: http://www.witech.com.cn **
CPU: S3C6410 @532MHz
Board: SMDK6410
DRAM: 128 MB
Flash: 0 kB
NAND: select s3c_nand_oob_mlc_128
2048 MB
In: serial
Out: serial
Err: serial
NAND read: device 0 offset 0x100000, size 0x300000
3145728 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux......................... done, booting the kernel.
Linux version 2.6.28.6 (root@ok6410-desktop) (gcc version 4.2.2) #236 Thu Jan 20 23:15:22 CST 2011
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C64XX: HCLKx2=266000000, HCLK=133000000, PCLK=66500000
div1: 00000555
mout_epll: source is fout_epll (1), rate is 24000000
mmc_bus: source is dout_mpll (1), rate is 44333333
usb-host-bus: source is mout_epll (0), rate is 24000000
audio-bus0: source is mout_epll (0), rate is 24000000
audio-bus1: source is mout_epll (0), rate is 24000000
audio-bus2: source is mout_epll (0), rate is 24000000
s3c64xx: 15728640 bytes SDRAM reserved for fimc at 0x50637000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x51537000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x51d37000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x52537000
s3c64xx: 8388608 bytes SDRAM reserved for jpeg at 0x52b37000
s3c64xx: 8388608 bytes SDRAM reserved for cmm at 0x53337000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
PID hash table entries: 512 (order: 9, 2048 bytes)
s3c24xx_serial_init_ports: initialising ports=4...
console [ttySAC0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 70200KB available (4596K code, 526K data, 148K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 530.84 BogoMIPS (lpj=1327104)
net_namespace: 316 bytes
S3C DMA-pl080 Controller Driver, (c) 2006-2007 Samsung Electronics
Total 32 DMA channels will be initialized.
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
NET: Registered protocol family 1 |
