查看: 15408|回复: 12
[已解决] 使用FL2440光盘提供的Linux内核和文件系统镜像重新烧写后系统没法启动
 火
zhaigf044 发表于 2009-12-12 13:19:34 | 显示全部楼层 |阅读模式
1.FL2440的光盘目录如下图所示:
2.其中提供的Linux内核和文件系统镜像在Linux文件夹中
3.一共提供了内核镜像zImage_1,zimage_2,以及文件系统qte_mouse.yaffs,qte_touch.yaffs
按照说明文档应该在下图的3kernel和5fs_yaffs分区烧写上面的镜像就可以了,但是烧写后Linux系统却没法启动。下面叙述一下烧写碰到的问题,希望斑竹能给些建议。我处理一个星期了,没能解决。
按排列组合一次烧写linux1.6.12文件夹的内核和文件系统
1.        内核zImage_1,文件系统qie_mouse.yaffs
Boot linux出现下列问题
NAND ID is 0xecf1
Set boot params = root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
Load Kernel...
Uncompressing Linux................................................................................................................... done, booting the kernel.
Linux version 2.6.12-h1940 (root@localhost.localdomain) (gcc version 3.4.1) #400 Fri Dec 5 12:16:19 CST 2008
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
S3C2440: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
Built 1 zonelists
Kernel command line: root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320
irq: clearing pending ext status 000c0000
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00500d00, tcnt a2c1, tcfg 0000020f,00000030, usec 00001eb8
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 60800KB available (2966K code, 912K data, 160K init)
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 96.000 MHz
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
中间有删节
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
nbd: registered device at major 43
ub: sizeof ub_scsi_cmd 68 ub_dev 2384 ub_lun 140
usbcore: registered new driver ub
Cirrus Logic CS8900A driver for Linux (V0.02)
dev->base_addr=0xe0000300<3>line 689 passed,request_region() OK!success get IO port address!
eth0: incorrect signature 0x0000
dm9000 Ethernet Driver
eth0: dm9000 at c49b8300,c49ba304 IRQ 51 MAC: 00:12:34:56:80:49
STRIP: Version 1.3A-STUART.CHESHIRE (unlimited channels)
Linux video capture interface: v1.00
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
SET CF & IDE WAIT!now BWSCON=225dd510
-1:no 0:ok ide_register_hw return -1
block2mtd: version $Revision: 1.23 $
s3c2410-nand: mapped registers at c4b80000
s3c2410-nand: timing: Tacls 10ns, Twrph0 40ns, Twrph1 10ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Bad eraseblock 381 at 0x02fa0000
Bad eraseblock 859 at 0x06b60000
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00100000 : "Boot"
0x00140000-0x00500000 : "MyApp"
0x00500000-0x00800000 : "Kernel"
0x00800000-0x04400000 : "fs_yaffs"
0x04400000-0x08000000 : "WINCE"
usbmon: debugs is not available
hello,enter new ohci-s3c2410.c
CLKDIVN = 0000000d
CLKSLOW = 00000004
CLKCON = 00f2e770
UPLLCON = 00038021
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.12-h1940 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
usb 1-1: Product: Generic USB Hub
usb 1-1: Manufacturer: ALCOR
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new driver usb-storage
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
pwc Philips webcam module version 9.0.2-unofficial loaded.
pwc Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
pwc the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
usbcore: registered new driver Philips webcam
usbcore: registered new driver gspca
drivers/usb/media/gspca/gspca_core.c: gspca driver 00.60.00 registered
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 390 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Bluetooth: HCI USB driver ver 2.8
usbcore: registered new driver hci_usb
hello,enter s3c2410sdi_probe()!!!!!!!!!!!!!!!!!!!!!!!!!
mmc->f_max =25000000
mmc->f_min =97656
mmci-s3c2410: probe: mapped sdi_base=c5000000 irq=37 irq_cd=62 dma=0.
mmci-s3c2410: initialisation done.
virtual address of s3c2410_va_iis=f0d00000.
next will do driver_register!
just enter s3c2410_uda1341_probe()
S3C2410-UDA1341 Probe
line 1314 passed! have set L3 mode=GPB2, dat=GPB3, clk=GPB4, output
line 1319 passed!
have set IISLRCK=GPE0, IISSCLK=GPE1, CDCLK=GPE2, IISSDI=GPE3, IISSDO=GPE4
line 1323 passed! have Enable IIS clock
success register irq: iisout_dma_done_handler
success register irq: iisin_dma_done_handler
UDA1341 audio driver initialized
driver uda1341 in /sound/oss/s3c2410-oss.c
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
Bluetooth: L2CAP ver 2.7
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM ver 1.5
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
yaffs: passed flags ""
yaffs: auto selecting yaffs2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
本人学习嵌入式时间不长,原因可能是内核能启动,但是文件系统却不能加载。主要信息就是红色字体。
2.        内核zImage_1,文件系统qie_touch.yaffs
Boot linux出现下列问题
和第1的错误一样
3.        内核zImage_2,文件系统qie_mouse.yaffs
Boot linux出现下列问题
和第1的错误一样
4.        内核zImage_2,文件系统qie_touch.yaffs
Boot linux出现下列问题
和第1的错误一样
现在操作了4遍Linux内核和文件系统烧写,计算机没有蓝屏。但是昨天晚上烧写过程中计算机蓝屏好多次。搞不清楚烧写过程中为什么计算机会蓝屏。
求各位大牛们给提点建议。我操作步骤应该没问题。飞凌公司提供的内核和文件系统有问题?我现在想恢复到出厂的设置怎么就不行了呢
phantom 该用户已被删除
phantom 发表于 2009-12-12 15:34:28 | 显示全部楼层
lfqsy 该用户已被删除
lfqsy 发表于 2010-3-13 17:47:18 | 显示全部楼层
u_showtime 该用户已被删除
u_showtime 发表于 2010-3-14 16:29:23 | 显示全部楼层
aggio 该用户已被删除
aggio 发表于 2010-4-3 16:15:01 | 显示全部楼层
yuziqiang 该用户已被删除
yuziqiang 发表于 2010-4-4 14:57:53 | 显示全部楼层
yeah79 发表于 2010-5-8 19:41:49 | 显示全部楼层
遇到一样的问题,如何解决的啊?急急急
it1988 该用户已被删除
it1988 发表于 2010-10-24 22:07:40 | 显示全部楼层
ゞωǒ_飛.. 该用户已被删除
ゞωǒ_飛.. 发表于 2011-1-3 00:37:23 | 显示全部楼层
ゞωǒ_飛.. 该用户已被删除
ゞωǒ_飛.. 发表于 2011-1-3 00:39:25 | 显示全部楼层
