查看: 4718|回复: 2
USB烧写LINUX下载FORLINX_6410_touch.cramfs校验不过
LiJunJohn 发表于 2011-4-30 10:23:41 | 显示全部楼层 |阅读模式
USB烧写LINUX下载FORLINX_6410_touch.cramfs校验不过,DNW显示如下:
U-Boot 1.1.6 (Feb 24 2011 - 14:27:19) for SMDK6410
**    Updated for TE6410 Board        **
**    Version 1.0 (10-01-15)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    256 MB
In:      serial
Out:     serial
Err:     serial
SMDK6410 # dnw 50008000
OTG cable Connected!
Now, Waiting for DNW to transmit data
Download Done!! Download Address: 0x50008000, Download Filesize:0x5a3a000
Checksum is being calculated...........................................................................................
Checksum Value => MEM:829c DNW:b35c
楼主| LiJunJohn 发表于 2011-4-30 11:53:33 | 显示全部楼层
另外采用一键烧写的方式进不了系统:
DNW显示的信息:
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 164K
hub 1-0:1.0: connect-debounce failed, port 2 disabled
/etc/rc.d/init.d/netd: line 16: /usr/sbin/inetd: not found
mkdir: cannot create directory '/mnt/disk': File exists
yaffs: dev is 32505859 name is "mtdblock3" rw
yaffs: passed flags ""
Try to bring eth0 interface up......eth0: link down
Done
Starting Qtopia2, please waiting...
Please press Enter to activate this console. touch...
飞凌-alexlee 发表于 2011-5-3 08:15:26 | 显示全部楼层
这个提示,已经进入到系统内了啊~
请到6410专区发贴~
