查看: 8544|回复: 3
请问fl工程师,我的flash是不是坏了!!!
17
LS1012A通行证LS1043A\46A通行证A40i\T3\T507\T527通行证i.MX8MM通行证RK3399通行证LS1028A通行证i.MX8MP通行证AM5718通行证AM335x通行证i.MX6UL通行证i.MX RT通行证i.MX6Q通行证XX18通行证
ty3655 发表于 2010-4-28 22:14:24 | 显示全部楼层 |阅读模式
刚刚重烧linux-2.6.28的内核和文件系统。
昨天还正常启动,今天就不行了。一直在黑屏状态。
Linux version 2.6.28.7 (root@localhost.localdomain) (gcc version 3.4.1) #336 Tue May 12 08:40:50 CST 2009
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
CPU S3C2440A (id 0x32440001)
MM: CPU does not support supersection mapping for 0x55000000000 at 0xf0d00000
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: root=/dev/mtdblock3 init=/linuxrc load_ramdisk=0 console=ttySAC0,115200 mem=65536K devfs=mount display=sam320 0
irq: clearing pending ext status 000df600
irq: clearing subpending status 00000093
irq: clearing subpending status 00000092
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00500d00, tcnt a2c1, tcfg 0000020f,00000030, usec 00001eb8
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61132KB available (3284K code, 312K data, 136K init)
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
net_namespace: 288 bytes
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
SCSI subsystem initialized
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (extended precision)
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
yaffs May  8 2009 10:19:56 Installing.
msgmni has been set to 119
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler cfq registered
Console: switching to colour frame buffer device 40x30
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Serial: 8250/16550 driver4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
Cirrus Logic CS8900A driver for Linux (Modified for SMDK2410)
eth0: incorrect signature 0x000f
dm9000 Ethernet Driver, V1.31
eth0: dm9000e at c487a300,c487e304 IRQ 51 MAC: 00:12:34:56:80:49 (chip)
Uniform Multi-Platform E-IDE driver
ide-gd driver 1.18
ide-cd driver 5.00
Driver 'sd' needs updating - please use bus_type methods
s3c2440-nand s3c2440-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Bad eraseblock 370 at 0x02e40000
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00100000 : "Boot"
0x00140000-0x00500000 : "MyApp"
0x00500000-0x00800000 : "Kernel"
0x00800000-0x04400000 : "fs_yaffs"
0x04400000-0x08000000 : "WINCE"
usbmon: debugfs is not available
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver
usbcore: registered new interface driver pl2303
s3c2410 TouchScreen successfully loaded
input: s3c2410 TouchScreen as /class/input/input0
s3c2440-sdi s3c2440-sdi: host detect has no irq available
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 196kHz (requested: 195kHz).
usbhid: v2.6:USB HID core driver
mapped channel 10 to 2
mapped channel 9 to 1
UDA1341 audio driver initialized
TCP cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
yaffs: passed flags ""
yaffs: auto selecting yaffs2
block 307 is bad
yaffs tragedy: Bad object type, 17 != 1, for object 499 at chunk 25789 during scan
yaffs tragedy: Bad object type, 129 != 1, for object 473 at chunk 25720 during scan
yaffs tragedy: Bad object type, 16385 != 1, for object 468 at chunk 25681 during scan
yaffs tragedy: Bad object type, 9 != 1, for object 342 at chunk 25482 during scan
yaffs tragedy: Bad object type, 0 != 3, for object 273 at chunk 25367 during scan
yaffs tragedy: attempting to use non-directory as a directory in scan. Put in lost+found.
yaffs tragedy: Bad object type, 2 != 3, for object 265 at chunk 25359 during scan
yaffs tragedy: Bad object type, 34 != 3, for object 263 at chunk 25357 during scan
yaffs tragedy: Bad object type, 130 != 3, for object 262 at chunk 25356 during scan
yaffs tragedy: Bad object type, 130 != 3, for object 261 at chunk 25355 during scan
yaffs tragedy: Bad object type, 2 != 3, for object 259 at chunk 25353 during scan
Partially written block 394 detected
Partially written block 392 detected
yaffs tragedy: Bad object type, 5 != 3, for object 256 at chunk 24569 during scan
yaffs tragedy: Bad object type, 1 != 3, for object 2305 at chunk 22670 during scan
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem).
Freeing init memory: 136K
Failed to execute /linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
飞凌-seventeen 发表于 2010-4-29 22:27:50 | 显示全部楼层
确定文件系统也是2.6.28的吗,他不能跟2.6.12的混用的
17
楼主| ty3655 发表于 2010-4-29 23:18:59 | 显示全部楼层
是,而且我烧写的是2.6.28和2.6.33两个版本都fail。
不过今天有利用bootloader擦除了文件分区后重写就OK了。
25
飞凌-fatfish 发表于 2010-4-30 08:16:20 | 显示全部楼层
烧写每个分区之前,建议先擦除这个分区,然后烧写。
