- 49
贡献50
飞刀12 FD
注册时间2016-6-21
在线时间44 小时
以下为打印信息,u-boot用的2.6.36的,linux3.0下的u-boot老是报ecc出错
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
vcan: Virtual CAN interface driver
slcan: serial line CAN interface driver
slcan: 10 dynamic interface channels.
CAN device driver interface
mcp251x: setup gpio pins CS and External Int
mcp2515 spi1.0: probed
PPP MPPE Compression module registered
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d081a000,d0c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new interface driver rt73usb
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 3.0.1 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver pl2303
dummy_hcd dummy_hcd: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd: Dummy host controller
dummy_hcd dummy_hcd: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Dummy host controller
usb usb2: Manufacturer: Linux 3.0.1 dummy_hcd
usb usb2: SerialNumber: dummy_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /devices/virtual/input/input1
i2c /dev entries driver
Linux video capture interface: v2.00
gspca: main v2.10.0 registered
usbcore: registered new interface driver benq
benq: registered
usbcore: registered new interface driver conex
conex: registered
usbcore: registered new interface driver cpia1
cpia1: registered
usbcore: registered new interface driver etoms
etoms: registered
usbcore: registered new interface driver finepix
finepix: registered
usbcore: registered new interface driver jeilinj
jeilinj: registered
usbcore: registered new interface driver mars
mars: registered
usbcore: registered new interface driver mr97310a
mr97310a: registered
usbcore: registered new interface driver ov519
ov519: registered
usbcore: registered new interface driver ov534
ov534: registered
usbcore: registered new interface driver ov534_9
ov534_9: registered
usbcore: registered new interface driver pac207
pac207: registered
usbcore: registered new interface driver pac7302
pac7302: registered
usbcore: registered new interface driver pac7311
pac7311: registered
usbcore: registered new interface driver sn9c2028
sn9c2028: registered
usbcore: registered new interface driver sn9c20x
sn9c20x: registered
usbcore: registered new interface driver sonixb
sonixb: registered
usbcore: registered new interface driver sonixj
sonixj: registered
usbcore: registered new interface driver spca500
spca500: registered
usbcore: registered new interface driver spca501
spca501: registered
usbcore: registered new interface driver spca505
spca505: registered
usbcore: registered new interface driver spca506
spca506: registered
usbcore: registered new interface driver spca508
spca508: registered
usbcore: registered new interface driver spca561
spca561: registered
usbcore: registered new interface driver spca1528
spca1528: registered
usbcore: registered new interface driver sq905
sq905: registered
usbcore: registered new interface driver sq905c
sq905c: registered
usbcore: registered new interface driver sq930x
sq930x: registered
usbcore: registered new interface driver sunplus
sunplus: registered
usbcore: registered new interface driver stk014
stk014: registered
usbcore: registered new interface driver stv0680
stv0680: registered
usbcore: registered new interface driver t613
t613: registered
usbcore: registered new interface driver tv8532
tv8532: registered
usbcore: registered new interface driver vc032x
vc032x: registered
usbcore: registered new interface driver zc3xx
zc3xx: registered
usbcore: registered new interface driver ALi m5602
ALi m5602: registered
usbcore: registered new interface driver STV06xx
STV06xx: registered
gspca_gl860: driver startup - version 0.9d10
usbcore: registered new interface driver gspca_gl860
gspca_gl860: driver registered
s3c-fimc: controller 0 registered successfully
s3c-fimc: controller 1 registered successfully
s3c-fimc: info ov965x_init
cym s3c_mfc_mememap: addr:5dff9000 size:1138688
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
S3C Rotator Driver, (c) 2008 Samsung Electronics
s3c_rotator_probe called
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
S3C CMM Driver, (c) 2008 Samsung Electronics
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
mmc0: new high speed SDHC card at address 8779
mmcblk0: mmc0:8779 SD04G 3.75 GiB
mmcblk0: p1
mmc1: new SDIO card at address 0001
ALSA device list:
#0: SMDK (WM9713)
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 05:54:17 UTC (946706057)
libertas_sdio mmc1:0001:1: (unregistered net_device): 00:27:13:ee:fc:45, fw 9.70.3p24, cap 0x00000303
libertas_sdio mmc1:0001:1: wlan0: Marvell WLAN 802.11 adapter
end_request: I/O error, dev mtdblock2, sector 0
Buffer I/O error on device mtdblock2, logical block 0
end_request: I/O error, dev mtdblock2, sector 8
Buffer I/O error on device mtdblock2, logical block 1
end_request: I/O error, dev mtdblock2, sector 16
Buffer I/O error on device mtdblock2, logical block 2
end_request: I/O error, dev mtdblock2, sector 24
Buffer I/O error on device mtdblock2, logical block 3
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
[<c00490e4>] (unwind_backtrace+0x0/0xf8) from [<c047c8d0>] (dump_stack+0x18/0x1c)
[<c047c8d0>] (dump_stack+0x18/0x1c) from [<c047c938>] (panic+0x64/0x188)
[<c047c938>] (panic+0x64/0x188) from [<c0008ee0>] (mount_block_root+0x278/0x2e4)
[<c0008ee0>] (mount_block_root+0x278/0x2e4) from [<c0008fa0>] (mount_root+0x54/0x6c)
[<c0008fa0>] (mount_root+0x54/0x6c) from [<c00090ec>] (prepare_namespace+0x134/0x198)
[<c00090ec>] (prepare_namespace+0x134/0x198) from [<c00084c0>] (kernel_init+0xec/0x120)
[<c00084c0>] (kernel_init+0xec/0x120) from [<c00434f4>] (kernel_thread_exit+0x0/0x8) |
