查看: 2879|回复: 1
OK210开发板刷linux失败,求指点!
tuogege 发表于 2015-5-13 20:08:55 | 显示全部楼层 |阅读模式
小白刷linux,采用官方镜像,在win7 64位 金士顿8G环境下制作引导SD卡,刷机失败,求高人指点,以下是打印信息:
FORLINX EMBEDDED U-Boot 1.3.4 (Dec 18 2014- 14:49:40) for SMDKV210
CPU: S5PV210@1000MHz(OK)
       APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz
         MPLL= 667MHz, EPLL = 80MHz
                          HclkDsys = 166MHz, PclkDsys = 83MHz
                          HclkPsys = 133MHz, PclkPsys = 66MHz
                          SCLKA2M = 200MHz
Serial = CLKUART
Board:  SMDKV210
DRAM:   512 MB
Flash:  0 kB
SD/MMC: 972MB
NAND:   manufac=2c dev_id=38
Nandflash:ChipType= SLC  ChipName=MT29F8G08ABABAWP
No No Calc pagesize, blocksize, erasesize, use ids table .............
NandFlash:name=NAND 1GiB 1,8V 8-bit,id=38,pagesize=4096 ,chipsize=1024 MB,erasesize=524288 oobsize=128
NandFlash Size is 1024 MB
The input address don't need avirtual-to-physical translation : 2c89d2a0
*** Warning - using default environment
Video: 800x480x16 73kHz 150Hz
Video: video_hw_init complete
Video: Drawing the logo ...
checking mode for fastboot ...
[Fusing Image from SD Card.]
Fastboot: employ default partitioninformation
[Partition table on NAND]
ptn 0 name='bootloader' start=0x0len=0x100000(~1024KB) (Uboot)
ptn 1 name='kernel' start=0x100000len=0x500000(~5120KB)
ptn 2 name='logo' start=0x600000len=0x300000(~3072KB)
ptn 3 name='system' start=0x900000 len=N/A(Yaffs)
Partition: bootloader, File:/sdfuse/u-boot-210.bin
Partition1: Start Address(0x2f10c),Size(0x1b35af)
reading /sdfuse/u-boot-210.bin
The input address don't need avirtual-to-physical translation : 20000000
The input address don't need avirtual-to-physical translation : 2004f000
327680 (0x00050000) bytes read
flashing 'bootloader'
NAND erase: device 0 offset 0x0, size0x100000
Erasing at 0x0 --  50d block at 0x00080000
OK
NAND write: device 0 offset 0x0, size0x50000
Start write uboot to nandflash.
1032192 bytes written: OK
partition 'bootloader' flashed
Partition: kernel, File: /sdfuse/zImage-210
reading /sdfuse/zImage-210
The input address don't need avirtual-to-physical translation : 203ef000
4125016 (0x003ef158) bytes read
4125016 (0x003ef158) bytes reset read
flashing 'kernel'
NAND erase: device 0 offset 0x100000, size0x500000
Skipping bad block at  0x00100000
Skipping bad block at  0x00180000
Skipping bad block at  0x00200000
Skipping bad block at  0x00280000
Skipping bad block at  0x00300000
Skipping bad block at  0x00380000
Skipping bad block at  0x00400000
Skipping bad block at  0x00480000
Skipping bad block at  0x00500000
Skipping bad block at  0x00580000
OK
NAND write: device 0 offset 0x100000, size0x500000
Main area write (10 blocks):
Bad blocks 2 at 0x100000 is skipped
Bad blocks 3 at 0x180000 is skipped
Bad blocks 4 at 0x200000 is skipped
Bad blocks 5 at 0x280000 is skipped
Bad blocks 6 at 0x300000 is skipped
Bad blocks 7 at 0x380000 is skipped
Bad blocks 8 at 0x400000 is skipped
Bad blocks 9 at 0x480000 is skipped
Bad blocks 10 at 0x500000 is skipped
Bad blocks 11 at 0x580000 is skipped
Bad blocks 12 at 0x600000 is skipped
Bad blocks 13 at 0x680000 is skipped
Bad blocks 14 at 0x700000 is skipped
Bad blocks 15 at 0x780000 is skipped
Bad blocks 16 at 0x800000 is skipped
Bad blocks 17 at 0x880000 is skipped
Bad blocks 18 at 0x900000 is skipped
Bad blocks 19 at 0x980000 is skipped
Bad blocks 20 at 0xa00000 is skipped
Bad blocks 21 at 0xa80000 is skipped
Bad blocks 22 at 0xb00000 is skipped
Bad blocks 23 at 0xb80000 is skipped
Bad blocks 24 at 0xc00000 is skipped
Bad blocks 25 at 0xc80000 is skipped
Bad blocks 26 at 0xd00000 is skipped
Bad blocks 27 at 0xd80000 is skipped
Bad blocks 28 at 0xe00000 is skipped
Bad blocks 29 at 0xe80000 is skipped
Bad blocks 30 at 0xf00000 is skipped
Bad blocks 31 at 0xf80000 is skipped
Bad blocks 32 at 0x1000000 is skipped
Bad blocks 33 at 0x1080000 is skipped
Bad blocks 34 at 0x1100000 is skipped
Bad blocks 35 at 0x1180000 is skipped
Bad blocks 36 at 0x1200000 is skipped
Bad blocks 37 at 0x1280000 is skipped
Bad blocks 38 at 0x1300000 is skipped
Bad blocks 39 at 0x1380000 is skipped
Bad blocks 40 at 0x1400000 is skipped
Bad blocks 41 at 0x1480000 is skipped
Bad blocks 42 at 0x1500000 is skipped
Bad blocks 43 at 0x1580000 is skipped
Bad blocks 44 at 0x1600000 is skipped
Bad blocks 45 at 0x1680000 is skipped
Bad blocks 46 at 0x1700000 is skipped
Bad blocks 47 at 0x1780000 is skipped
Bad blocks 48 at 0x1800000 is skipped
Bad blocks 49 at 0x1880000 is skipped
Bad blocks 50 at 0x1900000 is skipped
Bad blocks 51 at 0x1980000 is skipped
Bad blocks 52 at 0x1a00000 is skipped
Bad blocks 53 at 0x1a80000 is skipped
Bad blocks 54 at 0x1b00000 is skipped
Bad blocks 55 at 0x1b80000 is skipped
Bad blocks 56 at 0x1c00000 is skipped
Bad blocks 57 at 0x1c80000 is skipped
Bad blocks 58 at 0x1d00000 is skipped
5242880 bytes written: OK
partition 'kernel' flashed
Partition: logo, File: /sdfuse/logo.bin
reading /sdfuse/logo.bin
The input address don't need avirtual-to-physical translation : 200ea000
960000 (0x000ea600) bytes read
flashing 'logo'
NAND erase: device 0 offset 0x600000, size0x300000
Skipping bad block at  0x00600000
Skipping bad block at  0x00680000
Skipping bad block at  0x00700000
Skipping bad block at  0x00780000
Skipping bad block at  0x00800000
Skipping bad block at  0x00880000
OK
NAND write: device 0 offset 0x600000, size0x100000
Main area write (2 blocks):
Bad blocks 59 at 0x1d80000 is skipped
Bad blocks 60 at 0x1e00000 is skipped
Bad blocks 61 at 0x1e80000 is skipped
Bad blocks 62 at 0x1f00000 is skipped
Bad blocks 63 at 0x1f80000 is skipped
Bad blocks 64 at 0x2000000 is skipped
Bad blocks 65 at 0x2080000 is skipped
Bad blocks 66 at 0x2100000 is skipped
Bad blocks 67 at 0x2180000 is skipped
Bad blocks 68 at 0x2200000 is skipped
1048576 bytes written: OK
partition 'logo' flashed
Partition: system, File:/sdfuse/rootfs-210.yaffs2
reading /sdfuse/rootfs-210.yaffs2
The input address don't need avirtual-to-physical translation : 21fffe00
The input address don't need a virtual-to-physicaltranslation : 23fffc00
The input address don't need avirtual-to-physical translation : 25fffa00
The input address don't need avirtual-to-physical translation : 27fff800
The input address don't need avirtual-to-physical translation : 284a2000
139077312 (0x084a26c0) bytes read
flashing 'system'
NAND erase: device 0 offset 0x900000, size0x3f700000
Skipping bad block at  0x00900000
Skipping bad block at  0x00980000
Skipping bad block at  0x00a00000
Skipping bad block at  0x00a80000
Skipping bad block at  0x00b00000
Skipping bad block at  0x00b80000
Skipping bad block at  0x00c00000
Skipping bad block at  0x00c80000
Skipping bad block at  0x00d00000
Skipping bad block at  0x00d80000
Skipping bad block at  0x00e00000
Skipping bad block at  0x00e80000
Skipping bad block at  0x00f00000
Skipping bad block at  0x00f80000
Skipping bad block at  0x01000000
Skipping bad block at  0x01080000
Skipping bad block at  0x01100000
Skipping bad block at  0x01180000
Skipping bad block at  0x01200000
Skipping bad block at  0x01280000
Skipping bad block at  0x01300000
Skipping bad block at  0x01380000
Skipping bad block at  0x01400000
Skipping bad block at  0x01480000
Skipping bad block at  0x01500000
Skipping bad block at  0x01580000
Skipping bad block at  0x01600000
Skipping bad block at  0x01680000
Skipping bad block at  0x01700000
Skipping bad block at  0x01780000
Skipping bad block at  0x01800000
Skipping bad block at  0x01880000
Skipping bad block at  0x01900000
Skipping bad block at  0x01980000
Skipping bad block at  0x01a00000
Skipping bad block at  0x01a80000
Skipping bad block at  0x01b00000
Skipping bad block at  0x01b80000
Skipping bad block at  0x01c00000
Skipping bad block at  0x01c80000
Skipping bad block at  0x01d00000
Skipping bad block at  0x01d80000
Skipping bad block at  0x01e00000
Skipping bad block at  0x01e80000
Skipping bad block at  0x01f00000
Skipping bad block at  0x01f80000
Skipping bad block at  0x02000000
Skipping bad block at  0x02080000
Skipping bad block at  0x02100000
Skipping bad block at  0x02180000
Skipping bad block at  0x02200000
Skipping bad block at  0x02280000
Skipping bad block at  0x02300000
Erasing at 0x2380000 --   2complete.
Erasing at 0x2700000 --   3
Erasing at 0x3180000 --   4
Erasing at 0x3b80000 --   5
Erasing at 0x4580000 --   6
Erasing at 0x5000000 --   7
Erasing at 0x5a00000 --   8
Erasing at 0x6400000 --   9
Erasing at 0x6e00000 --  10
Erasing at 0x7880000 --  11
Erasing at 0x8280000 --  12
Erasing at 0x8c80000 --  13
Erasing at 0x9700000 --  14
Erasing at 0xa100000 --  15
Erasing at 0xab00000 --  16
Erasing at 0xb580000 --  17
Erasing at 0xbf80000 --  18
Erasing at 0xc980000 --  19
Erasing at 0xd380000 --  20
Erasing at 0xde00000 --  21
Erasing at 0xe800000 --  22
Erasing at 0xf200000 --  23
Erasing at 0xfc80000 --  24
Erasing at 0x10680000 --  25
Erasing at 0x11080000 --  26
Erasing at 0x11b00000 --  27
Erasing at 0x12500000 --  28
Erasing at 0x12f00000 --  29
Erasing at 0x13900000 --  30
Erasing at 0x14380000 --  31
Erasing at 0x14d80000 --  32
Erasing at 0x15780000 --  33
Erasing at 0x16200000 --  34
Erasing at 0x16c00000 --  35
Erasing at 0x17600000 --  36
Erasing at 0x18080000 --  37
Erasing at 0x18a80000 --  38
Erasing at 0x19480000 --  39
Erasing at 0x19e80000 --  40
Erasing at 0x1a900000 --  41
Erasing at 0x1b300000 --  42
Erasing at 0x1bd00000 --  43
Erasing at 0x1c780000 --  44
Erasing at 0x1d180000 --  45
Erasing at 0x1db80000 --  46
Erasing at 0x1e600000 --  47
Erasing at 0x1f000000 --  48
Erasing at 0x1fa00000 --  49
Erasing at 0x20400000 --  50
Erasing at 0x20e80000 --  51
Erasing at 0x21880000 --  52
Erasing at 0x22280000 --  53
Erasing at 0x22d00000 --  54
Erasing at 0x23700000 --  55
Erasing at 0x24100000 --  56
Erasing at 0x24b80000 --  57
Erasing at 0x25580000 --  58
Erasing at 0x25f80000 --  59
Erasing at 0x26980000 --  60
Erasing at 0x27400000 --  61
Erasing at 0x27e00000 --  62
Erasing at 0x28800000 --  63
Erasing at 0x29280000 --  64
Erasing at 0x29c80000 --  65
Erasing at 0x2a680000 --  66
Erasing at 0x2b100000 --  67
Erasing at 0x2bb00000 --  68
Erasing at 0x2c500000 --  69
Erasing at 0x2cf00000 --  70
Erasing at 0x2d980000 --  71
Erasing at 0x2e380000 --  72
Erasing at 0x2ed80000 --  73
Erasing at 0x2f800000 --  74
Erasing at 0x30200000 --  75
Erasing at 0x30c00000 --  76
Erasing at 0x31680000 --  77
Erasing at 0x32080000 --  78
Erasing at 0x32a80000 --  79
Erasing at 0x33480000 --  80
Erasing at 0x33f00000 --  81
Erasing at 0x34900000 --  82
Erasing at 0x35300000 --  83
Erasing at 0x35d80000 --  84
Erasing at 0x36780000 --  85
Erasing at 0x37180000 --  86
Erasing at 0x37c00000 --  87
Erasing at 0x38600000 --  88
Erasing at 0x39000000 --  89
Erasing at 0x39a00000 --  90
Erasing at 0x3a480000 --  91
Erasing at 0x3ae80000 --  92
Erasing at 0x3b880000 --  93
Erasing at 0x3c300000 --  94
Erasing at 0x3cd00000 --  95
Erasing at 0x3d700000 --  96
Erasing at 0x3e180000 --  97
Erasing at 0x3eb80000 --  98
Erasing at 0x3f580000 --  99
Erasing at 0x3ff80000 -- 100et 0x900000,size 0x84a26c0
Input block length is not page aligned
Data did not fit into device, due to badblocks
139077312 bytes written: ERROR
flashing 'system' failed
SMDKV210 #
楼主| tuogege 发表于 2015-5-13 20:11:41 | 显示全部楼层
PS:复制打印信息时,采用的是1G SD卡,后采用推荐的8G 金士顿卡,错误依旧!
